This is my effort so far on the Watson generator and it does not work as I connect all 4 coils in series and connect it to a 470uf, 400v cap which I tried to switch only when the voltage over it reached about 60v as described in numerous drawings on the web
On John Bearden website: The Tom Bearden WebsiteErwin's Work Shop
Bedini 1984 Radiant Energy converter
"The Watson Machine"
explains the parallel resonant effect used , but I cannot determined if he ever got this thing working.
John Bedini also give construction notes where he uses 6 coil of only 200 turns of 20awg wire. That gives me a coil of low resistance (2 ohms) ,as I suppose for parallel resonance you need low resistance, but the coil than measures only 8mH which give me a capacitor of 165uf(2x 330uf in parr) @ about 140hz which is the freq. with 6 magnets when the motor is pulsed(12v wiper motor) A big capacitor! I did not try it out with this coil and cap yet
I tested a222mH coil with a cap on a ssg motor and got a much bigger voltage at resonance. It also charged a big cap after the bridge up much faster.
Will try experimenting in the following week
