CloudSeeder's Gravity Wheel on Fire
  • The 22nd was overly optimistic of my abilities to fabricate the next one (below) but the designs are all ready, and some of them simply blow me away. I was planning to show this one first but I made some last minute pre-22nd additions to it that made it too intricate for me to build. Here it is not yet finished and shelved til I have more $$$$ =>
    The one above is a lot like a pelican shape, this one's the "double-opposed dual pendulum" design. And now that American electric consumers know for a fact they are being over-sauced by their friendly electric companies (APCO, AEP and so on), people will know for a FACT they can power their homes with Wind, Solar or Gravity.
    Open Road now Cloxxki <> Jam the Pedal to the Metal.
    Re: Nation&#039;s Electric Company Billing Scam on Consumers // Current
    Last edited by CloudSeeder; 09-23-2009, 03:11 PM. Reason: American electric consumers know for a fact they are being over-sauced by their friendly electric companies
    • "Peacepipe4" is just my YouTube username, not a channel. When I get one of these babies to spinning I will put it on YouTube posted under peacepipe4 and also featured on a new website => www.justgravity.com . At present I am seriously short on funds (had to help my son out of a pinch this month).
      I have found out that one person working alone shouldn't set Dates... but that's okay too because the delays gave me valuable time to perfect my designs. Gravity is toast Cloxxki. American electric power companies are falling like pieces of burnt toast right now.
      The beast is on his knees <> where's our sword?
      • I used these broad width popsicle sticks for the side pieces on the last design but afterward I drilled one and it split. So the reason they're smeared with paint is that that isn't paint. That's liquid metal paste I smeared on the sides to reinforce the wood, keep it from splitting when it came under spinning pressures.
        • and Trickle Money too!
          252 volts slamming America electric meters full speed ahead!
          Over-exaggerated Need for Electricity Scam to
          Stop Green Energy!
          • Over Voltage status
            I can only agree with this. After reading this, now I know why my three UPS's have been squeaking at me all the time. Not under, but over voltage
            Bout time to hook up a sample system and capture the data live to the disk and then post it.
            thay
            • That's right Thay. I first noticed this over voltage in 1999 when I bought my 1st mobilehome. It was in a different area east of here (Bedford Va) under a different power company. I tried to raise the issue but they stomped me like a cigarette claiming it was normal and I was all wet.
              Of course THEY had all the electrician company credentials and to them I was a camel dump so they stopped me then, because I was very ill and Mom was about to pass away. I was too wasted and ill health to stay with the fight.
              Then when I moved here the monthly bill stayed the same, and we were not using that much power again! We've all been screwed to the wall, repeatedly, and done to everybody.
              These people have been dropping a rug over our head and beating us to a pulp. They haven't done anything less than roll us like a wino in an alley. They're pushing so much voltage (pressure) into our homes the cotton pickin' current is crossing through the air from one side of the receptacles to the the other, depending on amt of moisture in the air.
              And when the grease fires kill more people in teh U.S. than any other fire, it's obvious when the stove element heats up once it reaches top heat it's still pumping that extra 20 volts. That's what's causing so many Americans to die from grease fires in the home.
              20 volts extra at the bottom, no problem.
              20 volts at the top, a problem.
              • Thanks Thay for adding that about the UPS units going off because mine did that some too. Hadn't thought about that! The men who checked the voltage who work here at the apartments, they said the Current was actually LOW at 37. It's supposed to be 40 they said. If it was 40 my voltage would be 272. I conducted my own "Field Test" over the past months by turning off breaker switches in the circuit box to everything I wasn't using. I got my monthly bill down to $46. Then I stopped turning the switches off and it went right back up to yep, $89.91 right where those bastards oops dirty scum want it to stay.
                Here's my Field Test screenshot =>
                At first I wasn't real good at remembering to turn off the breakers, but as I got better at doing it the monthly bill continued to drop lower & lower after March and April went by (2009). Be advised though Thay <> I fried the apartment's heat pump. Too much voltage bounced into it.
                Last edited by CloudSeeder; 09-23-2009, 06:57 PM. Reason: I conducted my own "Field Test" over the past months by turning off breaker switches in the circuit box to everything I wasn'
                • I just now for the 1st time ever added up the first 31 months of my usage history and got the average monthly bill: $85.54; then the next 4 months when I was keeping the breakers turned off to restrict trickle current = $53.44 per month.
                  $85.54 minus $53.44 equals $32.10 multiplied by 35 months tells me how much overcharge, equals $1,123.50 <> I know for a fact this has been happened for the last 10 years <> which would be $374.50 times 10 equals $3,745.00.
                  I've paid out an extra $3,745.00 the past 10 years for trickle current being shoved thru my meter. That was from two separate electric companies. I had a different company in Bedford Virginia than the Appalachian Power Company "APCO" here in Roanoke Va.
                  In Bedford I had a brand new mobilehome, all new wiring you know. So when the bill kept hitting $90/month and all we were doing was running two computers, me and the boy who was 6 at the time, barely doing any cooking, I knew something was wrong then. Yep, something was wrong alright. Both their hands were squirming around in my pockets.
                  The reason we left Bedford was because one night our big nice microwave suddenly turned itself on and caught on fire. The electricity stream arced from the rotator motor up to the microwave bulb, passing through the heavy ceramic rotator plate giving it a black melted place in the middle (through the middle). I told Greentree Mortgage it was faulty wiring throughout the trailer and our lives were in danger, and gave it back to them. ((The microwave was plugged into a special ground fault automatic shuttoff receptacle that didn't shut the microwave down as it should have.))
                  Most Americans would never take note of these things as I have. I've been on full disability since 1989. I had time to take notes. "Greed knows no father" they said in the movie The Ten Commandments but this greed is from the stockholders of the Crude Oil, Coal and Natural Gas industries... soaking their own children and grandchildren to stay in good standing at their church. $4,000.00 from every household in America per each decade is a really large wad of cash. If it was just done here in Virginia you're still talking a lot of Sunday tithing and election contributions to get "their man" re-elected.
                  Woodrow Riley, 9/23/2009 <> thoroughly disgusted
                  However, we should not miss the full importance of what this overcharging means. It means all their calculations of how much energy we will need being produced ~as the TV lady spokesperson tells us as she walks across the stage~ produced by 2025 is entirely fabricated and fictitious, a number drawn out of electrified air ~ WHICH MEANS ~ the argument that Americans can't possibly survive on just solar and wind is a patent bald-faced lie.
                  I proved it with my homemade field test.
                  Wait a minute. OK, I did make a mistake. I failed to give them a break for winter & summer temperature spikes. My bad. I guess I'm just kind of upset over this crap.
                  Last edited by CloudSeeder; 09-23-2009, 11:10 PM. Reason: Crude Oil, Coal and Natural Gas & Electric Power CEO's worse thieves of American's hard-earned money than OPEC.
                  • Since the Resistance of my mobilehome and then the Resistance of this apartment were basically EQUAL (because our number of appliances remained equal) the excess voltage raising the trickle current is nearly a Constant $32.00 extra a month. That would mean I was correct. $32 x 12 x 10 = @ $3800 for the past 10 years being pushed too much voltage in Virginia.
                    The week is past, haven't heard a peep from anybody.
                    • I'd love to try and contribute, but a find myself incapable of interpreting your wheels/pendulums designs, even afer you provided photos.
                      Perhaps until you collect funds to construct, you may be able to similate them in a program such as Phun or WM2D? I've recently seen some nice sims in Phun, but have not tried it myself yet.
                      • You contribute plenty. I agree, the photos show a lot but the few things they don't quite show are important. I thought I'd put them out for people to see... anyone who can use a new idea to apply toward their own wheels. I couldn't hardly find the pieces of wood already cut to width so I took the wide popsicle sticks and glued them to make them. They seem to have to much flexibility. I may have to coat them with liquid metal paste to add stiffness.
                        • @Cloxxki: Well, to be brutally honest with you I've been having an issue with weakness in my upper spine next to the neck that has been dogging me for ages. It drains me mentally when it's like that. Saps me of the energy & drive I need to drive these wheels home.
                          I'm really getting ticked off about it. I was filled with those darn Lyme's disease spirocheates from late 2006 into February 2007 before I was able to beat them back. I don't know if it's them trying to get started in on me again or perhaps they chewed off some of the trunk nerve's myelin sheath.
                          It seems to be letting up a little today so I'm hopeful of getting back in the fray. I've got the two wheel designs all figured out what needs to be done with them. Even with just the pictures you have an idea of just how beautiful they are but I've made some rod length and angle changes to the big one looks like a pelican. Apologies for the long wait.
                          I've noticed Space-X has had their problems in that regard also => Space tourism yet to fly, 5 years since 1st flight - Yahoo! News
                          They are really very simple. I'm two left hands
                          • How UFO's Work: Gyyroscope System to Hover / Weighted Ring+Sledgehammer Drive =&gt;
                            UFO's stand still in the air by kicking in multiple gyroscopes. When sudden takeoff motion is desired the gyros are stopped and a spinning weighted ring engages a sledgehammer to hit in the direction desired. Very fast starts and sudden stops. Most likely unmanned, remote-control craft that would kill a living pilot. Gyro~Stop & Sledgehammer~Bang. To go up or down just tilt the spinning weighted ring around into position before hitting Stop.
                            Hint: the "sledgehammer is in the center of the craft, uses Leverage Energy. Only The CloudSeeder knows this. Sshhh. Top Secret. p.s. The jokes on us since 1950's.
                            For you SkyWatcher.
                            The weights are near the center <> the rings are at supreme velocity but have v/little weight so they can be stopped with a brake. When the ring is braked to an instant halt the weights near the center go flying outward sliding on a rod, and when the weight hits the end of the rod its centrifugal force jerk-propels the craft in that direction.
                            Last edited by CloudSeeder; 10-05-2009, 11:02 PM. Reason: <> How UFO's Work: Gyyroscope System to Hover / Weighted Ring+Sledgehammer Drive <>
                            • APCO Correction 10/06/2009 Lights Stopped Flickering
                              @Thaelin: @All: I noticed an APCO vehicle speeding past my apartment yesterday, and this morning the power went off for 5 minutes around 9 AM. When power was restored the dual fluorescent kitchen bulbs stopped flickering. They have flickered like that since 2003 when we moved in.
                              So I continued working on the computer ((because it's an Eee pc with a battery plugged on the back so it didn't get shut down when they turned off the power)), when the refrigerator compressor-motor came on and was running much more smoothly.
                              I seriously doubt they will show enough respect toward me to tell me what was wrong, but if they do I'll let you all know. Apparently they all have a great disrespect for apartment renters & people on disability. They uhm heh heh heh will have a greatly increased respect for us now because Woodrow Riley aka the CloudSeeder rained some truth down their collar and told them their job.
                              They've been cattle branded on their APCO hide. Whether they pay their electric consumers any monies back remains to be seen. I'm not holding my breath.
                              • Smack Plates are just a Sideways Pendulum Stopped Short.
                                10/19/2009 => Smack Plates are just a Sideways Pendulum Stopped Way Short of Full Swing.
