What the "Gravity Wheel Winner" will look like? July 24 2009 Friday update:
@All: I have a sneaking suspicion that the Either-Or question ~whether the opposed arms or the 3-legged Kostoff solution is best~ will turn out to be that the Gravity Wheel Winner will be so "right" that it will work no matter whether the arms are Even or Odd groupings. If one arm is right they may very well all be right however many are place on the hub.
I want to favor the 3-grouping because one is happening (Present) the next is coming (Future) and the 3rd is already happened (Past)... so that once it is given a spin start it's never satisfied to stay still. It's locked in an unsatisfied state that should never find resolution; and yet they usually do get resolved by friction. Eliminating the friction would make a gravity wheel locked in Time, Present Future and Past constantly exchanging places.
You would think friction could be easily resolved by using an axle grease that becomes more fluid as it warms, but unfortunately when grease warms it slides out of place and you're back having more friction. If we had powerful enough magnets holding the axles suspended, or if we had the axle ends in an air-contact-only suspension of some type, that would be the end of all friction holding these devices back.
But how to create the vacuum of space only in the axle ends?? It cannot be
done because it would introduce too much wobble. How to create a bubble
of air for the axle ends to ride on??? An airtight seal would stop the axles
from even turning! A dialable electromagnet above the metal axle ends?
Yep. But that would be cheating.
A Gravity Wheel would not generate enough power to #1 power two electromagnets enough upward pull to suspend its own weight <> #2 plus spin its own weight <> #3 plus turn a generator... but the electromagnets could, after all, be powered by a windmill and solar panels combined system's battery bank... Certainly would work!
At any rate, the #2 design -which I have not released or shown in any drawings- will work because it borrowed somewhat one of Kostoff's tricks. The #3 design came very close to achieving continuous spin but even if it had I'm unsure it would have also turned a generator. I've also built the #4 Gravity Wheel now and while it should have exceeded #3, it did not; it added too much weight to total weight. But in being worse it showed me a major flaw in them all. I believe #5 has the greatest chance of all my designs including the first ones, the disks. It looks like it will work whether a triple arrangement or opposed arms arrangement. It has Winner written all over it. #5 is projected to get done sometime in August, still keeping in mind my earlier commitment to August 31.
When we cross this wall there won't be any turning back. ~ CloudSeeder, July 24 2009, a Friday
