Originally posted by Vortex
The Physics of the Primary State of Matter
Behind on the reading
Must admit I'm behind on the reading list. This gravity mill is an obsession for me lately.
That sounds like a wonderful lab :-) have you guys got skype accounts? I get 4000 min free on my phone plan (inc downloads) that I've never used, so if anyone's interested we could chat about any of this stuff over skype. Pm me if so.
Love and lightAtoms move for free. It's all about resonance and phase. Make the circuit open and build a generator.
Bodkins
Hey, I just went into a trance or something writing on the self run bedini thread. Thoughts and impressions got in order.
Fluffy charge and magnetic fields make sense now.
Sweet.
Here's what I posted there:
re timing ; what if the coil's magnetic field collapses after the magnet has passed quickly enough, (to be honest I haven't done this yet - working with a pendulum so the magnet is at a standstill when I fire the coil) it will be a little like as if the core was magnetised by the coil acting like an electromagnet.
That bit is theory.
Experiment has proven that an energized coil (magnetic field) connected on one end to source negative will, if the power sustaining that magnetic field is abruptly removed (in bedini system this is removing the battery positive and there is no current, just magnetic field. In theory the same thing is happening with an abruptly collapsing core magnetic field with battery neg or ground connection and a neon. No current, rapidly collapsing magnetic field.) anyhoo, the voltage (radiant event / inrush of aether) causes a spike of pure-ish voltage.
Experiment has shown me that yes the inrushing aether will supply current from a no current state in a coil and will jump a neon to a place of lower potential.
and yes, the battery will charge if not connected to source battery but it will be fluffy and won't run a load.
This is because it is aether inrush. Like two waves meeting together that kick up a huge splash, the inrush seeking to fill the void left by the magnetic field (which was holding the aether inflow at bay? Like a high pressure system that pushes away low pressure systems in weather just disappearing, all the low pressure would rush in..
So the aether that jumps the neon into the battery is different to normal charge. Normal charge sucks electrons out of the battery positive.
Radiant charge places a condition of vacuum-ness into the actual battery.
So that won't run a load, but it will cause electrons to be sucked up from an actual ground.
Viola, the charge will be more able to bear a load.
I've lost track of myself. Hope it makes sense.
Oh yeah, I don't use a diode. Just neon and ground. Haven't yet done extensive testing; the above just came to me in last two days.Atoms move for free. It's all about resonance and phase. Make the circuit open and build a generator.
I had seen that also. I could not confirm so I left it as a "bug in the ear"Originally posted by Bodkins View PostCaduceus Coil Observations
Still trying to catchup on all the great info you put together Randy also looking at the adam ant book!
Seems worth toying with, but I'm here not to lead and hopefully not mislead.
The Adam Ant ebook, (AAE)
yes.
Adam Ant was the messenger, he delivered the ebook.
I posted the Content of the ebook which begins here
taking 3 postings due to a single post has a size limit of I believe 12,000 chars,
therefore it took 3 postings to list the contents
Gravity and magnetism
Ok..
Two analogies. Both quite limited, so bear with me.
Picture a bath full of water. Now pull the plug. A whirlpool develops. This is an electron or proton. The water is the aether. What's it doing? It is trying to fill the hole in the middle of the whirlpool. Nature abhors a vacuum, and by rushing in actually makes the whirlpool keep spinning. Picture many whirlpools over the plug hole. Now, at the other end of the bath, picture another whirlpool. Where's it going to go? There is a net movement towards the massive body.
Gravity. Funny that richardson and morely tried to measure aether drift, and all the while it was holding them down.
Now, what happens when we get a bunch of whirlpool / vortices / electrons, and cause them to travel along a copper wire?
Next analogy.
Zoom out on your image of the whirlpool in water until the whirlpools are really really tiny. There's lots of them.
Put the bath water in a washing machine. That's a cross section of the copper wire....
One difference to keep in mind is all the whirlpools all spinning the same way, all keeping each other at arms length.
They would spiral along the conductor. More so if the random molecular movement of atom's nucleus didn't interfere. This explains superconductors. And why heat stops magnetic field.
I continue..
Put the washing machine on spin. Centrifugal force of electrons travelling along the conductor is the magnetic field. It makes a low pressure zone in the aether that also holds the aether surrounding the conductor in a state of stress.
Remove the magnetic field and the stress field collapses, creating an inrush. Radiant event.
The inrush will cause electrons to form in certain atomic lattices as the aether is forced to spin.
Etc etc......
Enough ranting from me for now.Atoms move for free. It's all about resonance and phase. Make the circuit open and build a generator.
No, It's for viewing electrolyte activity .. unless you are using an electrolyte somehow.Originally posted by Bodkins View Postis there anything we can do with the machine I have, what do you think?
That does not mean you can't do what IFs using electrolyte ..
but electrolyte is nothing like air or vacuum so then you must ask what is gained.
I have not Cross-Posted this yet. A DO-NOT-MISS VIEWING Look at it.
Method of viewing magnet flux fields in real time, live!
Also note sucahyo's following post which he observed a MATCH between the
100 years ago occult chemistry images and modern day images. Again I had
see the occult chemistry, but I made an error in judgment leaving out a reference to it.
Lucky for us sucahyo made the connection.
Ben
YouTube - Electric flow HV
think about in Ben the vortex around and in the middle of the wire is the eye!
In a coil the field will collapes to the middle of the iron(carbon centre)of the coil pushing the energy out or in, Like I always said its a pump.
I have seen this before but didnt pick up on it.Originally posted by Vortex View PostNo, It's for viewing electrolyte activity .. unless you are using an electrolyte somehow.
sorry sort on time again!!!!
ben will talk soon
http://register.skype.com/en-gb-skype?cm_mmc=google/latsearch-_-EU-UK|EN|RELAT-_-BD-_-kwid=JFT007019|creative=2603329180&JAWS=zhx0y8
Aae
The ebook was a work in progress, what we have is unfinished ..
The ebook, we have, has only has 36 chapters, so searching for "THE HOUSE OF JUDAH" returned 144,000 HITS..from AAE on Page 1186
All of this information in the letter is ongoing formal research and analysis that is above and beyond the original 1500 page document in your hands. This research is the expansion of the Chapter 54 John Lennon chapter, when a massive discovery changes everything you believe and were taught in secular academic school and religious church/synagogue/ mosque.
That number slaps me in the face
, so I search the ebook and find:
The entire spiritual nervous network totals 144,000 pathways.
The entire chakral and nadi network of oriental medicine concerns the 144,000 nerves within the physical body.
That 144,000 number is also seen in the New Testament Book of Revelation.
SPOOKY isn't it...
KeelyNet: Les Brown ( A Memo Regarding the Brown Video (May 22, 1994) ) | MERLib.org
It would be nice to find this Brown Video.
Les Brown: Physics of Crystals (this seems to be part of the Brown Video)
Ref Videos: Directory:Videos - PESWikiRemember to be kind to your mind ...
There is additional note from and other report:Originally posted by Bodkins View Post
Translated version of http://www.nulpuntenergie.net/frank/esk-meerinfo.htm
There is a step by step photo too here:In the Mediterranean Olde World, this image is the Caduseus, staff of Hermes, ancient Greek messenger of the Gods. His staff traces to even more ancient Egypt, to Thoth, Teacher of Enlightenment and Founder of the Mystery Schools. Today this emblem persists as symbol of Medicine—modern society of healers.
Ancient tradition explains when twin Serpents twined about our spine ("S" = Serpent + Pine) stand on their tails to feed their neuro-nectar to Eagle, they unite into winged serpent:
bron: http://home.tiscali.nl/tutanchaton/C...xplanation.htm
An explanation to a friend:
Hi Horst, long overdue! What does 0. mean? No division, the primordial state of non-seperation. Male+fe-male. The thing that is before the ying-yang. The coils are like a body for that kind of energy to enter our plane. Computers are developing an emotional body. For sake of contrast, first the down to earth facts. We currently (pun) have two types of coils. The "old ones" that conjure up personalised soul energy. The "new type", as presented by Robert last friday, which envokes the raw unpersonalised energy of existence as such, light, subtle and joyfull. Practical experience: I was in Rotterdam making the "old type" coils with some spiritual women, including ME. After winding the coils we exchanged coils to feel them. On touching I got a complete "energy pattern picture" from the person who wound the coil. No further introduction needed. Rank and serial number not relevant. Very intimate. On holding a "new type" coil last friday, I got the picture of a sort of white cloud with human like beings floating peacefuly in that space, inside the coil. One (British) guest at our table did a heart-of-heart meditation which she shared through a small new type coil. Every one had his/her experience. I've put my personal old type coil in the electricity circuit powering my computer and now I'm very happy with the radiation from my screen. It neutralizes all non-domestic energies, including whatever influences are being sent with the house-hold current and TV-cable current (I've made a coil using co-axial cable as used in antenna). It's a practicle science. I measure the coils by touching them and sensing the tingling. A pendulum works as well. I'm certain that when you combine this technology with the DNA spiral, you have a very usefull combination. Always happy to keep up good conversation, Hugo
http
for tranlation use dutch, if some text aren't translated use german.
I lag behind in reading too lol.
I wonder what happen if we make a coil exactly the same as picture bellow?
Here is a strange phenomena on my recent circuit. Even when there is no change in frequency or voltage, the neon light move up and down periodically. Looks like pulsing.
YouTube - Neon bulb lighting part change locationLast edited by sucahyo; 03-13-2009, 04:37 AM.
As above, so below
As above, so below (short version of saying)Originally posted by sucahyo View PostI wonder what happen if we make a coil (Caduceus Coil ) exactly the same as picture bellow?
You will see the small looking like the large and the large looking like the small.
The human cell looks like the human body for example (shape wise no, but parts and pieces, yes) It's easier to see the shapes when they are the same, it's harder to see it when they are not the same shapes.
I'd give out links here, but they would only confuse.
It took me a while to "feel" (a hold) this idea and a couple of "head drumming" to get the message to stick. I remember my first thoughts when I first came across this was something like "Oh, that's cute, that's nice."
Without having a "vision" in the mind of what it is you want to "See", the
"as above, so below" is a useful thing for "seeing".
As you stated: the coil looks like the positive/negative picture.. for Example.Remember to be kind to your mind ...
24 frames Per Second
sucahyo, your video "Neon bulb lighting part change location"
yes, most strange, I don't know what it means,
but it brings to mind what I post below.
That's your mind's speed limit, 24 frames (snap shots) per second.
Think of a strobe light on the spokes of a fast moving wheel ..
Depending upon the speed of the strobe light the spokes rotate clockwise or
counter-clockwise, but we see only a blur without the strobe light.
Your mind's speed limit of 24 frames per second is like a strobe light flashing upon the world.
What I see in those 24 snap shots of time per second will not be what you see in the same second.
Our strobe lights are not in SINK and flashing at the same time.
We all see a similar but a different reality.
If you watch a video that has 30 frames per second, you will NOT be seeing
at least 6 snap shot images per second of the video. If you rewind and watch
the video again, you could see something you never saw before due to the
timing of your strobe light mind (the speed limit of your mind) ..
Only frame by frame viewing will allow you to SEE the entire video.
Two people looking at the same thing. One can SEE something the other
does not see, happens all the time. Their strobe light view of the world
is not in SINK and each sees something different.
Sight is a really poor tool for observation, understanding it's limitations
allows you to make better use of it.
Randy
P.S. I regret I did have any links or videos handy to reference for this.
(oh, the speed limit can be broken
Flavio Thomas - Pyramid energy power shown powering ...
We already have a topic started about this video is at the forum here.
Thomas Trawoger (aka Flavio Thomas?) how to documented at peswiki
The web site HAS been taken down.He has been approached by a well-funded group to develop this technology.
That groups required him to remove his website from the net.
sucahyo
Randy
Its look very interesting the stuff you two have put up but I think i need around a year (LOL) to get all this stuff im my head.Im also reading Arron book and watching his videos,feels like im walking over things I already now!
The good thing at the end of the month Im on night, so i get a good 50 hours of research done at work,my job so cool for that.
Update on my eletret! its not to good i dont think i did it right, the cooking was off!!
its can be used as a antena but that not the point!!!
Take Care
Rx
I dont now what to make of the light, sucahyo also was it you with the blowing water I have found that the flyback transformer kickout lots of wind, will upload a video if you wish?Last edited by Bodkins; 03-13-2009, 07:25 PM.
