Could I add a few things here?
.....+<----(*)<---(Charges are attracted at different speeds depending on
...+<-------(*)(intensity of these radiative events at that time as we modulate
(the voltage potential. They are transverse to the modulation)
This is a wave form of ac. Much like the description of the wave of the water. Do you see the periods going up to the +'s. Those are radiative tendrils of lines of force or "magnetic" waves coming from the wires. You need to understand that this radiative emission happens in time. Meaning we modulate the potential of the wire to attract the charges at different speeds along the wire. Now to truly understand what is going on here is that this is only a 2d view of this event. When viewed in a 3d perspective like the whole surface of the water and not a slice it all changes.
Current Flows into our system through those wires. It is attracted to the potential via the dots. Those dots line up with very little effort in a static nature. And the charges ride those lines into the wires internal lattice of locked in connectors. This allows the metal to conduct those charges and move along the internal lattice.
The problem is that AC or the back and forth method of exciting the wires causes us to force the movement both ways due to the inertia of the energy flowing twords the source. This is a very resistive event. And it creates a lot of re radiative effects. So some have found a way to take the whole and use it in such a way that reduces that resistive event. This is called resonance and resonance is a bandaid to the problem. It doesn't solve the problem because all the theories we are using are based off of the 2d pictogram I have provided you.
When we use the natural method of attracting the charges without repelling them we have a limitless charge potential when we follow the fluid flow method like Tesla was trying to show us after he realized he was making the resistance himself in his first attempt with the AC method.
There is no field other then the charge carriers lining up. And it doesn't extend outwards with an active field. The charge carriers are only a static mechanism that guides the charges to the wire and allow it to flow to the higher charge well or higher static source through the metal of the wire. Current in that case is a feedback to the source. And using the rules of flow of fluids it needs an in and an out. We have the in via the wires but where is the out. This is where Bedini came into play. He had the in but not the out except for the non active plates in the battery. This caused the battery to charge up and an imbalance was made in the battery via the solution of water and acid. This caused the acid to become more energized and increased the static action of the battery. Meaning it reved up the solutions flow increasing the charge hitting the positive plate for a small amount of time.
I hope you guys understand that we have partial understanding of the effects of voltage but we are misunderstanding a lot about everything else. We use terms like Magnetism, fields and currents without knowing their true natures. This is because we could never know their true natures by just looking at that particular event. A good majority of which is invisible to us. But we can infer what is happening through observations of the effects and by understanding that even though we don't believe it we are in a medium much like water. It changes density as we go further up until there is very little density at all. With the highest density being in water.
We are in a fluid density but that density is less then the water so we get a separation of that density. This separation also exists in out atmosphere, cloud layers and even exists in the density of that and outer space. To get back to near earth events like currents of winds and the likes we can see that we are in fact in a fluid medium. So what can we infer from knowing that? Well fluidic laws must apply. We also know that pure voltage is static in nature so that means the other law is statics. We can further include geometry to those laws as well knowing that there is some matter that has a geometry causing the static nature. And last but not least the laws of resistance. Those laws of resistances need to be modified slightly because now it is of a fluid nature of resistances combined with the rest of the laws and walla we have the clues to figure what nature runs off of.
