self charging batts
First, I used a mechanical switch and is the only way I did it when I got the effect.
Second, a load test will obviously show how much load it can pull for so long..but that isn't necessary to prove the concept.
Input battery is irrelevant for this concept as well...the concept is simply...will the self-charging phenomena produce any kind of load powering charge and not just fluffy voltage?
Just look at the output battery. If the batter is 12volts and I charge it and it gets to 12.5v and I turn everything off and it climbs to 13.0v...that is half a volt all by itself. Most of us know that turning it off at 12.5 will show an immediate drop when disconnected from the SG. Now lets say it sits for a bit and falls to 12.8v from 13.0v.
If I power a load from that battery and I get any kind of work from 12.8 down to 12.5...that is real load powering capability with that voltage that went up by itself after disconnecting. That means that is isn't a fluffy phantom voltage effect but something that will give you actual work in joules of energy. This is not to say some of the upper portion of the charge isn't fluffy but not all.
Anyway, this is my 2 cents based on actually doing it.
If anyone wants to use a trifilar coil with the recovery charging cap banks to lower voltage...around 2-4 volts over what the battery is and close to 200,000 uf's...discharge that with a mechanical switch on a pulley...you'll find out how real the effect is and that it can power a load.
Of course you'll need to size the pulley appropriately so the cap bank gets charge a few volts above the battery voltage over 1 complete rotation.
Resting time between cycles does absolutely effect COP. You wait too long to charge and drain again and efficiency goes down. You need to do the charging/drain cycles like you have OCD (obsessive compulsive disorder) and you'll see that the efficiency goes up...do it non-stop and you'll see high gains...skip even 1-2 days and you'll see efficiency go down.
Don't do it with solid state switch, diode off the collector, etc... just do it like I did and like John did. It may be more efficient in the long run doing it with a spike off the coil direct to a battery and this is maybe why John went that route or maybe just because it is simpler and eliminates a lot of extra parts.
I was just curious if the effect I'm seeing is similar to the one you observed, but apparently it isn't the same thing...
oh, and while I'm interrogating you
do you remember the frequency of the pulses?
