The Mechanical Engine
  • CloudSeeder
    Like everybody else here we all need to build our ideas, even if they don't work and then show them not working. Then suggestions could be made I guess. You might could gradually knead in a few more explicit terms, give us some awe to chew on.
  • Michael John Nunnerley
    Originally posted by CloudSeeder View Post
    Whew! Now I know what my ideas must sound like to everybody else! It's so, so clear to the person WRITING IT. I have trouble converting 2-d static pictures into motion also. Without having a pipe tap to insert into the other person's brain I can get really Lost in Translation, and I don't even get the blond. Darn that Bill Murray.
    Your right it is a problem, I could go into scientific terms, which is my job, but I think it will make things worse
    Michael
  • CloudSeeder
    Originally posted by Ted Ewert View Post
    Hi Michael.
    Interesting concept you have there. I appears it should work at first glance, but I don't think it will. The reason is that you essentially have two wheels, with two axis, that are connected together. You could have two gears rotating on two axles connected together via their teeth and you would have the same thing.
    There needs to be a dynamic phase shift between centrifugal and centripetal forces during each cycle. These two phases of rotation have to be separated by time and space. This means one axis has to shift away from and back toward the other.
    Look at the axis of your weights; it doesn't shift. This is why it can't work. Thousands of unbalanced wheels have been built using this same principal, and none of them work (I know because I've built a few myself ).
    I don't mean to be discouraging, but this is the reason I've jumped on Peter's bandwagon. I believe a self powered wheel is possible, but only under Nature's very specific conditions.
    I'm in the process of designing and building a wheel along the principals of Peter's design, so I'll be putting my money where my mouth is. You can all have a good laugh if I screw it up.
    Ted
  • Inquorate
    Waiting for payday...
    Still waiting for payday to get a big piece of plywood and a couple of bolts etc.. Bit crestfallen about ppls findings from attempts so far but also encouraged by simple experiments with a Crossbeam and two pendulums, one swinging..
  • Ted Ewert
    Originally posted by woopy View Post
    hello all
    i began with Inquorate idea for a simplification of Peter Lindemann excellent version of Bessler wheel
    than i tested it in WM 2d and in the simulation after some modifications it worked very well
    but after having been encouraged by these simulations i decided to build the wheel
    i made it with 5 and than 10 fulcrum(pendulum) and it didn't work
    as i said in one if my previous post "i hoped that reality will not be to severe against us but in fact reality has not to be severe ,it is simply reality
    and believe me when you turn with your hands on your bench the wheel with 10 heavy pendulums ,you get at once the reality. You feel the possiibility or not in some seconds and you deeply think that computer are big liers
    don't worry i am very confident that i made all the possible mistakes in the use of WM2d soft, as i have no experience with this soft
    just for info i make all my previous flight test of my ultralights with computer simulation and i can get very good accuracy between sim and reality and believe me i fly every day with the computer engineered flying machines and this is full reality
    but i use my flight sim since more than 6 years and i know all the small tricks to get the best usefull results
    now back to Beslaurentius code
    i have made further test this evening
    and i made comparison between free fall of the fulcrum without ratcheting the back swing
    and the same swing with the back swing on the ratchet
    the result is that the ratcheting backswing seems to offer more power and i can get almost 1/2 turn on one single swing
    once more feel free and i encourage you to build the system it does not take more time than learning to use a soft and make lot of expectation and at the end you will have anyway to confirm the soft calculation by building a proto to harness the Reality
    all the best and courage
    Laurent
    Hi Laurent,
    Someday computer sims may be able to help design these wheels, but not yet. Nobody knows enough about the principals behind a working model to write the software.
    I liked what you said about rotating the wheel with your hand and feeling the possibilities. You can get a lot of information from a machine just by moving it around and feeling the forces and stresses.
    We'll figure this out.
    Ted
  • CloudSeeder
    Well, if we can defy gravity then we can harness it and use it. I personally think defying it should have come 2nd... and well, it did. Bessler did it 200 years before Wilbur & Orville!
  • woopy
    hello all
    Laurent
  • CloudSeeder
    I won't laugh, and I'm thankful not too many people laugh when I go out on a long thin limb and make suggestions of possible ways to solve these issues... that may very well be nice theories and turn out to be just nice theories.
  • Ted Ewert
    gravity engine
    Hi Michael.
    Ted
  • CloudSeeder
    Building on #186 => http://www.energeticforum.com/50338-post186.html then, 3 pendulum units would be plenty, but you would need double the number of posts for them walking backwards to have somewhere to step backwards to... because the ones dropping back do so before the next one moves outta the way.
    A fresh post has to move up first, giving the unit somewhere to go.
    The position of the inner and outer cams is critical, as you will see there is a type of pendulum effect in two planes as the sliders move from one side to the other and then back again. The sliders have a ball race, they move very, very freely.
    I SHOULD SAY OFF SET PENDULUM EFFECT
    The disc size should be 1mtr. dia minimum. The shaft is connected to the disc but does not pass through or touch the slider bars, it extends out the back of the disc and passes through a bearing ready for usable energy pick up!!!!!!!!!!!!!!!!!!!!!!!
    gravity engine
    this is the diagram
