Originally posted by Peter Lindemann
A cam doesn't really bear any weight, it merely redirects it. A certain amount of energy has to be expended in order to move a weight out of it's circular orbit. I'm using ramps to do this. If the arm of the wheel wasn't holding the weight, the weight would accelerate down the ramp past the arm. The wheel is what is absorbing the kinetic energy of the weight as it tries to accelerate down the ramp.
The ramp also has another function. It allows the weight to accelerate while the wheel stays at a relatively constant speed. It does this by virtue of the increased distance the weight has to travel to cover the same arc that a weight in the circular orbit travels per unit of time.
Friction is really the only loss here. Nevertheless, I do think the angle and distance of the ramp are fairly critical. This is where my headache begins.
I got my 40" wheel assembled today. I still have to finish the frame and cams, which I hope to get done tomorrow. Here's a shot of the wheel.
This is how I configured the weight on the slider. Pretty basic, it has the bearing on top which will run along the cam. The weight is 1 lb, with the whole movable assembly weighing close to a pound and a half.
Cheers,
Ted
my wheel weights are one of the same, external cam and wheel, but I have left on the bolt sufficient to put extra weight if I need too. I was thinking of the diameter of the cam wheels, I think that it might be important, the smaller they are the more revolutions they will make and visa versa
There is one point that I am sure of and that is the cams must be fluid like I have shown you in the last drawing which I did on my cad program. The pivot point should be ,how I see it, at a little past 5 o'clock and a little before 1 o'clock on the internal cam. The pivot is important, this is our lever effect and the power is amplified from one side to the other, no laws broken here, only using old tech: but the possible gain, AT the moment we do not know, is the gain of momentum of circular motion
Genius Extra Point, pulling the opposite pendulum closer to the hub.
