Did you know?
Ever swung a bucket of water on a rope? Y'know; swing it all the way over your head and the water stays in the bucket and doesn't fall out...
How about swinging the bucket of water, pulling back on the length of rope when the bucket passes your feet, so that when the rope is at 45 degrees to the ground, the bucket hangs upside down in the air for a moment..
Then you have to press one palm on the midway point of the rope and pull the end back and up; otherwise the rope goes slack and the water comes out to see what all the fuss is about..
That moment of weightlessness is not what we want. We want the water pressing firmly on the bottom of the bucket, for sure, but we want it pulling us off our feet..
Have you ever swung a bucket of water (or a rock on a rope) over your head, around and around - while standing on the crest of a steep hill - and tried to underarm catapult said rock as far as possible?
the technique is different from when you are standing on flat ground.
When on flat ground, you want a mix of up and out...
But that same angle when catapulting the rock downhill will spend too much time going up, and then fall very steeply without much horizontal travel time.
Throwing a more shallow trajectory will mean the rock's kinetic energy will spend itself in more horizontal movement, and will not be fighting gravity, but instead using it...
If we hold onto the rope instead of letting it go:
while throwing the rock up and away - we will be pulled up off our feet. We don't want this, it is expending energy fighting gravity.
While throwing the rock out and away - we will be pulled down the hill, and jill comes tumbling after.
In short, we're all thinking of maximizing the centrifugal force at the bottom of the pendulum's swing by possibly using a spring to make the pendulum spend more time underneath the pivot point.
Why are we doing that? Try swinging a bag of tennis balls behind you then bring if forward from behind your back, past your feet and bang! Into a brick wall so the bag of balls goes back behind your feet.
It doesn't make sense if what you're trying to do is lose your balance.
Instead, swing the bag of tennis balls from out behind your feet, past your feet, and whoosh! Out away from your chest.
You'll be pulled away from your centre of balance, and then very easily follow the bag forward. Now, if you're on the crest of a hill, the bag will end up back at your feet, and you'll be tumbling after.
The best research for centrifugal force is a bag of weights, a rope, and a hill.
Love and light
Love and light
