How to gain Extra Energy from a pulsed Coil
Home made reed switch
Check out this guy's video
YouTube - 002 - selfmade magnetic or mechanic switch
And my version, still incomplete
YouTube - regarding high speed mechanical switchingAtoms move for free. It's all about resonance and phase. Make the circuit open and build a generator.
The Razorblades are better better better
Additional to my Circuit above, you can wire a poled Cap together,
and connect both Ends to the Output. It works like a Buffer.
Place it between + and - will cause a short.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
Beating razor blades
So far, striking them against different wires etc by hand (c200v ? Meter's lie) to get purple flash in neon using joule thief circuit, the legs of neon, enamel coated copper wire, and alligator clip ends, all started pitting before the razor blades. Methinks they are made of high grade steel, hence springyness. Also, they're relatively cheap and can be found at grocery stores or failing that, at barber / specialist shaving shops.Atoms move for free. It's all about resonance and phase. Make the circuit open and build a generator.
MY Favorites are now Ballpen springs
They moving faster and easier and more precise.
But Razorblades can handle couple Current, i think up to 20A?
Till they melt, even :P.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
Another source of springs is lightersOriginally posted by Joit View PostMY Favorites are now Ballpen springs
If you are a filthy, dirty, disgusting smoker (like me
) you'll have an endless supply of these springs
But they do tend to melt with high amperage
but you can get around that by putting a wire down the middle of it and use the end of the wire as the contact
I am one from those filthy Smokers too.
But we got by us mostly only refillable Electronic lighters.
For now, i take any Ballpent i can find apart. :P
But this is a good idea with the Wire.
I did make the last one inside a Hull of a Pen, and fixed it with Glue.
Then its kinda shockproof.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
Switches
Perhaps we should put this info under it's own thread re ingenious trashcan switching devices :-) - make it easier for ppl to findAtoms move for free. It's all about resonance and phase. Make the circuit open and build a generator.
Permanent magnet core
Any gains in field collapse are offset by extra EMF resistance in coil wire.. And vice versa.
This is odd, I sound like I know what I'm talking about. Year ago I only knew first year high school electronics, and that faded by 20 years... Who says you can't teach an old dog new tricks eh.Atoms move for free. It's all about resonance and phase. Make the circuit open and build a generator.
Magnet Switch Easy to Build
Only take a relay, take it out the cap, put a little neo magnet above in repulsion mode
.... Works well....
Big relay has a spring, is possible mod the spring to make it weaker....Your time is limited, so don't waste it living someone else's life. Don't be trapped by dogma — which is living with the results of other people's thinking. Don't let the noise of others' opinions drown out your own inner voice. And most important, have the courage to follow your heart and intuition. They somehow already know what you truly want to become. Everything else is secondary.
Steve Jobs. Apple CEO
