R. Adam's secret: Radiant AUTOGENERATOR COIL
  • Ok.... I'm going finish with this...
    The schematics was corrected, look C1, is like you said me, for resonance with the coil in paralel, so, like in my theory this is not resonance.... Look the first schematics with mosfet and transistor, capacitor is not for resonance, is only a path..... Here the schematic with switch.... Yet if you remove the diode D1, in that configuration you don't get a good HV spike.
    With this last schematics is exactly to original when I started this thread, you'll need think if this is resonance really.
    Steve Jobs. Apple CEO
    • I have discovered willhelm muller secret and i have developed an novel idea incorporating the three tecnologies.
      Adams/muller free radiant energy generator, for all.
      Muller generator generates high current, but mine concept is different.
      • Originally posted by darkwizard View Post
        I am eagerly waiting for you to share your design. Thanks darkwizard.
        http://blog.hexaheart.org
        • Originally posted by patmac View Post
          Ah! I was also baffled by the schematics you posted earlier but now D2 makes sense! But I would have thought the current passing through D2 to charge C1 generated by the magnet leaving the generator coil would put drag on the rotor (conventionally) since the current would form a magnetic field that would attract the departing magnet
          ( a few minutes later )
          then again... if C1 is discharged back through the coil at TDC (meaning the pulse would initiate directly at TDC) it would push the departing rotor magnet away... so, yes, the forces could balance out and you could use the flyback from the pulse to charge C2 without putting drag on the rotor.... possibly... hmmmmm.....
          I don't have the apparatus to test the circuit at the moment but, like Jetijs, i a also following this thread with interest
          • Also everone on the sg earth battery/stubblefield energy cell are watching this thread. Looks like the time can be a nightmare
            • Alright, i tried that circuit, here are my results: It did charge C2 very well, however it also put a load on the rotor, actually it behaved exactly like my original circuit i was using, shorting the coil directly to itself. And you are right, no resonant effects appear to be present there. Perhaps im doing something wrong I wish others would start working on this to try and confirm your results. I have however been having good success with my latest circuit i posted above. It definitely has a resonant effect to it, you need to adjust that C1 value for given rotor speed(frequency) to get the max HV output, while still putting no load on the rotor other than the magnet attracting to the core while its leaving. I believe my circuit will preform very well using a wind mill type generator coil(air core/w strong neo's) that should allow me to have no drag at all in theory since there will be no core for the magnet to attract to while its leaving. I question how well the coil will self induce using an air core, but for now i think this is the direction im going to pursue.
              • Right circuit is a trifilar coil for a pulse motor, every coil can be many coils in series with only one circuit, 3 windings, two power windings, and one generator winding , all at the same coil core, here the trigger coil is replaced with a reed switch, so a timing wheel must be constructed with tiny but powerful magnets, the generator winding catches the magnetic field from the magnet on the virtual south pulse and a residual radiant energy on the core , so it drags a little the wheel, but the drag is minimal, because the generator winding is shorted one time per revolution, and it adds torque to the wheel, and the radiant is captured on the charging battery.
                Left circuit is an "almost zero drag" generator, the pulse must be very short, the coils must be connected like the diagram says, and can connect many coils in series.
                • cody, yes, if you put, a capacitor when is charged to 5 volts aprox, the drag begins, but you'll notice if you put a batt for example, drag is less than with cap, but is better than connecting the coil directly.
                  never I told have made a mystic machine (That said Bedini), only that is better than traditional setups.
                    Hi darkwizard,
                    Would you mind giving some comments on your concepts WRT the schematics, please.
                    Thanks, Gyula
                    • I'm currently constructing my wood rotor, hahaha with hd bearings
                      • darkwizard
                        I think that your idea is great, is good, to know more about Muller system (y)
                        • If we put the two wires of the coil together, the drag will appear at the arrival of the magnet because the induced "current" creates a magnetic field that opposes the change of the magnetic pole.
                          • Everything is discussed
                            • Updated version, no lenz drag
                              • @patmac
                                would I be right in thinking this is the method of operation for the last circuit you posted? I think I might have made the reed switch's "close time" a bit too short but you get the idea.
