Bridge Rectifier and Power Convert
  • Bridge Rectifier and Power Convert
    Hi, I have bee scouring the forum for the answer to this question
    to no avail.
    I am a bit confused on how to best stop using brute force (12v
    30+amps) and begin using 110v and less amps. What I have learned would
    be to use a simple power inverter. With that being said. All the power
    inverters I have seen go from a cig lighter(or hard wire from the
    battery) to having a plug receptacle or two on the other end. My
    question is, would I need to modify the receptacle end or do just use
    4ga wire with a plug at the end? (so i guess my question is how do i
    connect the AC end to the (below mentioned) bridge rectifier. Or is this a power inverter that can be purchased that is pre-built with feature.
    The other question is: I have learned then after the power inverter
    would come a "bridge rectifier". What type, size rating, etc.. do i
    use, if using a 110v power inverter? (i.e 1000v 25amp) does anyone
    reccomend a source to find these?
    I also intend on using a Dave Lawton style PWM or a Bob Boyce PWM3G.
    Does anyone have any input to which would be best?
    BTW im completely open to any other input that may take me in a better
    direction.
    I hope i was able to ask my questions clearly.
    Thanks in advance for any input
    scott
    my suggestion is to use a de regulated alternater if your using your cell in a car. it wont burn out and you can use a pwm to control it. if you want to find out more pm me
