ELECTRET, CAPACITOR or OTHER
  • ELECTRET, CAPACITOR or OTHER
    Has anyone here produced any kind of device (circuit or component) that self generates .5-1V? Note: NOT using an earth ground, or trigger power source.
    maybe
    The nathan stubblefield earth battery does it.
    I've seen .8 volts plus some amperage with no ground and no trigger only power source I can think of would be the meter itself.
    Does that count?
    Peace
    PJ
    A Phenomenon is anything which can be apprehended by the senses.
      i did today .
      I tried this Setup from Antony Meiers, who did someone mentioned.
      He wrapped wire around a magnet, in middle halfed and said, he got couple Volts out.
      This did not work for me, but as i did connect one Wire to the magnet in the middle, i got inductive 0,5V, but no amps.
      And i did take 2 Screws, what i did stick left and right side from some stronger NE Magnets.
      --Edit- Since i saw Sigzidfit posting ...
      and a Pencil and a sharpender makes 1,5V 0,3 mA. its Graphit and Magnesium.
        Cap self charge
        Bodkins and I have both found that after conditioning a cap with dc square wave pulses for a day or so will change it so it self generates voltage. I used 555 timer, bodkins used bemf ( he would say time )
        Nat once measured his ignition coil gaining hundreds of volts. An Electret would work also. See dmonarch's Electrophorous thread
        For theory behind how, read dmonarch's radiant matter thread, I think it's page 2
        Might I ask what you want it for? I'm intrigued
          Sig
          Without an earth connection?
            Joit
            This one?
            Dr. Anthony Meiers
            I am searching for repeatable results, regardless of location.
              Inq
              "conditioning a cap with dc square wave pulses"
              I have a cap (5v) that I can "condition" and it will self regenerate (5v), but each discharge causes it to bounce back lower and lower until .1v remains.
              But it still bounces back 10-20 times before the voltage becomes unusable.
              "Might I ask what you want it for? I'm intrigued"
              Put a mirror in front of a mirror, look down the tunnel and see what you see.
              That is where I am going...
                Bodkins
                I have read parts of that document before... but at the bench I have not been successful. I will give it another look. Electret's have some significant promise....
                Have you produce one successfully utilizing these guidelines?
                  DavidE,
                  Yes, without an earth connection.
                  I've made several of them now and a good example did .8 volts, but even the worst did at least .5
                  I'm looking at one right now in a plastic container on a plastic table. The only thing connected is the meter. It is reading .512 v.
                  Peace
                  PJ
                    Originally posted by DavidE View Post
                    Bodkins
                    Not yet still getting stuff together will share results(have a friend how has success with it)
                    will check my stubblefield when i get in, its not ground because it in a plastice box i had 1.2volt with diodes and a antenna on the negative side, its been on a charging battery side of a imhotep fan for two days now
                      How about few thousand volt static charging
                      Radiant Energy Diatribe speaks of Static Electricity and electret effect
                      On web page under "Conditioning the Cable" it tells how to make an electret out of coax cable.
                      I'm wanting to make use of a lot of Cat-3 wire I have, few hundred feet.
                      All this wire needs to be put to work instead of doing nothing at all.
                      I thought if I stripped off the outer insulation and separate the 8 wires into single wires this would work?
                      I'm wanting to make the Perreault Conversion Circuit without electret, just using normal wire.
                      Randy
                        Evidence suggests that, the rate at which certain reactions occur is increased in the presence of high voltage.
                        • #14
                          Water batteries do this easy.
                          take a zinc slot cover from a computer, then take a copper wire put in a glass of water... .5V
                          See my experiments here...
                          • #15
                            Checked it up 2.2volt its going up over time
