HV Radiant Pick up of Inquorate
@Inquorate
I will try to explain, but if you do not understand please talk to me and I can try to make drawing; or expand on the words.
1. We know for a fact now that Universal (Radiant ?) energy passes right through most materials.
2. We also know that our circuits generates plenty of HV in the environment, as can be picked up by neon light in hand all over.
3. We need something to measure the energy we are picking up be it HV or Radiant; and I think you are on to something here.
Suggest to try the following:
A: Rather than bell, try to make a parabolic pick up. Can use ball and slice about 1/3 off. Now, cover with 5 layers of material:
Layer #1 – copper of aluminum foil, no problem either through steel would actually be better = I think.
Layer #2 – di-electric, can use few layers of cling wrap
Layer #3 – must be copper foil
Layer #4 – Same as # 2
Layer #5 – same as # 1
In the center make a small hole, depending on your wire size.
Insert the wire/conductor which should be something like coaxial (OK) or impedance wire (Better)– wire in center. Typical this is the type with wire in the core, plastic insulation around it and then weaved wire covered with another insulation. TV antenna wire is OK.
Connect the outer shield wire to the two outer layers of your pick-up.
Connect the inner core of the wire to the center copper/brass layer.
Connect LED or Neon to the inner core wire
Connect another to the outer shield wire.
Yes, this device will act like a type of capacitor, and it will also be possible that he two outer layers will act as primary to the inner secondary, but it would be good to try and experiment…..maybe.
What I THINK ! (Dangerous words) – All energy will hit the pick-up. Both the radiant and HV will charge the outer layers and light up that indicator. The Radiant will pass through and charge the inner brass, which normal HV will not do. It is sort of the inner brass in protected in kind of Farraday cage shield. If it is radiant and it charges the core copper, it will light up the main target neon.
Now, either way, you have a device that will also be very useful just in HV environment.
Next possible step:
The two neon light could be replaced by small Mercury vapor like balls – will probably have to manufacture this. Later I foresee this to be small spheres filled with gas similar to that in CFL or Fluorescent. This will light up. The intensity of that light is then measured to give indicator of strength.
Another option to play with is to change the pick up head from solid to be bifilar wound conical pancake coils i.e. Tesla pancake style.
@Inquorate
Next possible step:
little
