Aromaz Radiant Energy Joint Research Group
  • Water moving under hv
    What's in the water? Was one of those cups tea? is it acidic or alkaline? That would determine if more positive ions or more negative ions in the liquid, and would change direction of flow?
    Cool video.
    • Positrons electrons going backward in time?
      Read this page :-)
      Retrocausality - Wikipedia, the free encyclopedia
      And then this?
      http://en.wikipedia.org/wiki/Helmut_...rapsychologist)
      • Food for thought
        Its a little bizarre and might seem a bit off-topic, but i just stumbled over this article that contains some reflections on the connection between mind and EM and for sure is awesomely scary and interesting at the same time.
        Benjamin Fulford's 'Creature'(?)
          Unfortunately I don't know which part is positive or negative. I attach the cup and the circuit I use. It is tap water which I made dirty with battery carbon dust. I think anyone having induction coil collpase can replicate it if you can make 2 mm spark.
          Here is with better camera angle, from top:
          YouTube - High voltage can move water #2 vertical shot
          ether fish? or just worm adapting it self?
          About time reversal effect, isn't things happen because we plan it to happen?
          • Announcing my new lab assistant
            Unfortunately, neither of us seems to be the boss..
            YouTube - birds of a feather
            • [QUOTE=Aromaz;44956]THUNDERBOLTS OF THE GODS
              QUOTE]
              Since i saw this Video, my Conclusion was, even Current have to die to be reborn.
              But since that, there is no Aether for me anymore. There is only current, inductance and rubbing.
              Its all a cause of Current and EM and magnetical Forces.
              Even Earth gravitationals Pull is a cause of the EM Field of the Earth, like the Magnetfield, what drags to the Middle.
              And you been right with the Neg and pos Charge, its the turning Direction.
              Figure a Circle, where parts are at 9:00 and 3:00.
              They both are moving to 6:00. and one will get positive charge, and one negative.
              • [QUOTE=Joit;45411]
                • Just thinking
                  I've been thinking how to design a circuit / produce an event based on my current understanding of the aether.
                  One pivotal observation I have made is the spark itself. I asked myself, ''how does a spark know where to go?''
                  Electrons jump from a low potential (high pressure) to a high potential (low pressure) in a spark, but unless their path was predetermined in some way (and it is) then the electrons would uniformly spread out from one point (the negative electrode) in a sphere, until encountering the positive electrode.
                  But this doesn't happen. So why?
                  Also, there is a mechanism that determines the break - down voltage level of all matter; the point at which the electrons orbiting the atoms are ripped free of the nuclear bonds, and propelled towards the higher potential. Conductors do this easily, but at high enough voltage, all dielectrics become conductors - often with extra explosive results.
                  My assumption is thus; voltage potential creates (or is) a polarization of the axis of aether spin. Electrons spin one way, and will find the path to positive polarity easier. When the voltage potential is high enough, the electrons will even break free of atomic bonds (or tip over the edge of the atomic hill). This is why lightning is free electrons from the ground going up into the sky.
                  Protons spin the other way (have opposite charge) so want to travel the opposite direction to negative potential, but occupy more space and therefore have higher inertia. This is observed as gravity.
                  SO, the space between a voltage dipole is polarized.
                  What would happen if we suddenly created an area of extreme low pressure (pos) in an electrode, then reset to zero, but before the space became 'un'polarized we did it again and again, with successive unidirectional dc square wave pulses of extremely high frequency? What would happen in the sea of virtual particles?
                  What would happen then, if just beyond the dielectric breakdown distance, we placed a grid containing free electrons, considering that the space it occupies still has a high polarity of axis of spin?
                  Maybe the distance of the grid is the most important detail, and maybe gray's tube was sealed so that the same atmospheric conditions always applied, so that dielectric breakdown voltage was always the same...
                  Anyway, just thinking.
                  Ps tesla said that at high enough frequency of changing voltage between capacitor plates, the voltage can exceed the dielectric breakdown voltage. I believe the staccato changes in voltage polarity means the electrons will not release their atomic bonds.
                  However, would the bigger protons also not move? Or at high enough frequency, high enough voltage, would matter not release (most) of it's electrons (maybe a bit of corona discharge) but still impart motion toward the negative polarity??
                  • Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
                    • Hi Aromaz, i believe in what you say.
                        Electrons are there - already awaiting guidance. They are already
                        lined up as potential to the + wire and they are already lined up away
                        from the negative wire.
                        Keep this in mind and watch that excellent video of sucahyo again;
                        Before - way out before the spark; there is already turbulance in the
                        water. Just the potential alone causes this.
                        Now, one more experiment. HV line to spark gap adjuster, set your
                        spark gap a little (1 or 2 mm) bigger than what is required to jump the
                        spark. Insert then a thin piece of metal in the middle of the spark gap
                        - and see the spark going. That piece of metal (al sheet) is not connected
                        to anything.
                        • @sucahyo;
                          Excellent; very nice video of HV effect to water.
                          Shows the electrons seeking their destination!
                          • 'Electrons are already there, lined up..'
                            Yes, I agree. But what lines them up? Not the magnetic field, as there is none without actual current.
                            So we could say it's the electrostatic field that lines up the electrons. That is one explanation of the electret effect.
                            Which is why relative movement between an Electret and a magnet produces a kinetic force vector at 90 degrees to said relative motion.
                            But what is an electrostatic field, and does it exist independent of a medium, ie a vacuum?
                            Which gives me my next experiment..
                            Thankyou Aromaz
                            Does one plate of a capacitor, when in a vacuum, induce a charge in another plate a) outside of a vacuum b) within same vacuum.
                            Aim; determine if electrostatic field is a property of a vacuum, thus determining if another medium is present.
                            • The answers are pouring in
                              Video of sucahyo shows so nicely that the electric force can move the water,
                              now, read the biblical (and Jewish and Islamic) scriptures of the occurance
                              when Israel left Egypt and got to the Nile river: Exodus 14, Quran 26:63
                              Think HV electrical, From Biblical Exodus 14:
                              And the angel of God, which went before the camp of Israel, removed and went behind them; and the pillar of the cloud went from before their face, and stood behind them: And it came between the camp of the Egyptians and the camp of Israel; and it was a cloud and darkness to them, but it gave light by night to these: so that the one came not near the other all the night.
                              And Moses stretched out his hand over the sea; and the LORD caused the sea to go back by a strong east wind all that night, and made the sea dry land, and the waters were divided. And the children of Israel went into the middle of the sea on the dry ground: and the waters were a wall to them on their right hand, and on their left. And the Egyptians pursued, and went in after them to the middle of the sea, even all Pharaoh's horses, his chariots, and his horsemen. And it came to pass, that in the morning watch the LORD looked to the host of the Egyptians through the pillar of fire and of the cloud, and troubled the host of the Egyptians....."
                              wind, pilar of fire, cloud, noise, light...
                              THIS MIGHT - AS IN MAY BE - just one possible answer, it is still a miracle
                              but it could also show how natural forces could be used.
                                electrostatic field is the property of the stressfield in air i dont think you can get it in the vacuum.
                                If you use it in a vacuum I dont now
