Radiant Matter
  • #76
    Magnetic fields and the aether
    What does a current in a conductive medium, and a permanent magnet have in common? They both have a slightly warped - egg shaped - electronic cloud around the atom. Some materials (nickel iron cobalt) can have their atoms sitting side by side in such a way as to support this warping.
    A magnetic field is a particular resonance of aether vortices which must closely match the shape / size of electrons.. So a magnetic field will affect any substance which has mobile electrons; usually these substances would make good conductors.
    I have seen a video where a guy found that a board covered in neomagnets in same or different polarity arrangements, I can't remember, would fall slower (30%) than another board covered with same shape weight metal blocks..
    The magnetic board was setting up a condition in the aether both internally AND externally, thus giving it a wider area of aetheric whorls that would resist being changed ie higher inertia.
    So the aether flows thru these inertial vortices in the space of an object just like the previous analogy of little whorls on the slow moving river's surface. The whorls can move independently of the actual water flow. So there is the inertial whorls as well as longitudinal compression wave streams.
    The streams partially interact with atomic lattice of mass and impart motion. We call this gravity.
    Aether will stream from positive voltage potential to negative voltage potential, and in an electric circuit with magnetism, will also push electrons along a conductor. This electron movement we mistakenly think is current or electricity. But it is only an effect of the real energy stream in the aether.
    We can use electron movement or voltage dipole changes to start movement in the aether, but once the aether moves, it is only guided by the resonance of the circuit conditions, not limited to it...
    Aetheric streams do not need to be confined to conductors, they go thru all mass, and can also be directed to flow beside changes in density of dielectrics..
    Dielectrics can also be polarized electrically and this is where the Electret comes in.. An Electret and a permanent magnet will only interact when there is movement between them, and then the 'magnetic effect' is at 90 degrees.. Se an Electret must have a squashed atom where magnet has a squished one...
    Hope this all helps people understand the 'natural medium' a bit better, and also help see that all the 'forces' are just different effects of aetheric conditions.
    Love and light
    • #77
      Addendum
      I forgot to say that magnetic repulsion / attraction is just like how two whirlpools spinning in opposite directions will want to move away from each other, and same direction of spin will want to combine.
      Also, while little whorls in aether that move electrons want to move with the longitudinal compression waves, they don't have to.. At high enough frequency of abrupt compressions, the electron whorls remain unaffected, just like sound waves travelling thru the water in slow moving river will not affect the whorls on the skin of the water..
      And that's all that my brain has come up with for now :-)
      • #78
        fluffy electrons
        When aether streams travel along a conductor, with unidirectional dc pulses, the electrons don't have time to move. but just like a twig or branch stuck in the river bottom and sticking up above the water's surface doesn't move with the water's flow but does vibrate side to side because of the water's surface tension, so do electrons move side to side. This oscillations is what hertz mistakenly called electricity and it is what our instruments measure.
        But also if you watch the surface of the water, we get whorls of opposite spin but roughly same size and they move downstream slower than the flowing water.
        These whorls are same size of electrons but they won't attach to an atom, instead sitting in the space between atoms.
        Their spinning sets up oscillations in atoms nearby, and our volt meters see it as charge, but it's not. That's why we get fluffy voltage. The electron-like whorls will however behave like electrons in a running circuit, and moving thru or sitting in a battery or capacitor or dielectric (Electret) and will condition atomic structure which rearranges itself to have the whorls as neighbors.
        Once the atomic latticework is so arranged, it will more readily store these whorls, and some substances ( Electret / semiconductor ) will begin interacting with naturally occurring high frequency compression wave streams in the aether, and will self charge..
        This ladies and gentlemen is what happens in static electricity, which sets up an effect just like magnetic field in surrounding aether space and this is how an electrophorus static field detector works..
        • #79
          Inquorate
          Just starting to get my head around this stuff need time to see it as clear at you but I must Thank You for All the sharing of info. Brilliant!!!!!
          • #80
            Sharing
            Tis a pleasure to 'share the love' my dear bodkins. Nature wears a gossamer thin robe, and if you just watch closely you can see all her secrets. ;-)
            • #81
              Fireflys de coded
              To only understand the simple gloworm and its magic code
              Fireflys a worthy project of observations
              Noble lightning bugs. Unpluged!
              Acts 1:8
              • #82
                Book can be found here...
                Radiant Matter
                • #83
                  Radiant Matter
                  Sir William Crookes - On Radiant Matter
                  here too!!!!
                  • #84
                    I thought it had a lot of missing pages? But even the one I linked seems to be only 60 pages while the scanned one has a page number of 166. So I'm confused.
                    • #85
                      theres not much on each page of the 166 page version broli,the book maybe a bigger page size
