Magnetic fields and the aether
What does a current in a conductive medium, and a permanent magnet have in common? They both have a slightly warped - egg shaped - electronic cloud around the atom. Some materials (nickel iron cobalt) can have their atoms sitting side by side in such a way as to support this warping.
A magnetic field is a particular resonance of aether vortices which must closely match the shape / size of electrons.. So a magnetic field will affect any substance which has mobile electrons; usually these substances would make good conductors.
I have seen a video where a guy found that a board covered in neomagnets in same or different polarity arrangements, I can't remember, would fall slower (30%) than another board covered with same shape weight metal blocks..
The magnetic board was setting up a condition in the aether both internally AND externally, thus giving it a wider area of aetheric whorls that would resist being changed ie higher inertia.
So the aether flows thru these inertial vortices in the space of an object just like the previous analogy of little whorls on the slow moving river's surface. The whorls can move independently of the actual water flow. So there is the inertial whorls as well as longitudinal compression wave streams.
The streams partially interact with atomic lattice of mass and impart motion. We call this gravity.
Aether will stream from positive voltage potential to negative voltage potential, and in an electric circuit with magnetism, will also push electrons along a conductor. This electron movement we mistakenly think is current or electricity. But it is only an effect of the real energy stream in the aether.
We can use electron movement or voltage dipole changes to start movement in the aether, but once the aether moves, it is only guided by the resonance of the circuit conditions, not limited to it...
Aetheric streams do not need to be confined to conductors, they go thru all mass, and can also be directed to flow beside changes in density of dielectrics..
Dielectrics can also be polarized electrically and this is where the Electret comes in.. An Electret and a permanent magnet will only interact when there is movement between them, and then the 'magnetic effect' is at 90 degrees.. Se an Electret must have a squashed atom where magnet has a squished one...
Hope this all helps people understand the 'natural medium' a bit better, and also help see that all the 'forces' are just different effects of aetheric conditions.
Love and light
Love and light
