Resonance Effects For Everyone To Share
  • Second coil on JT
    Originally posted by slayer007 View Post
    @ Lidmotor
    Did you try adding a secondary coil on your JT yet?
    Sorry I have not yet. I was busy today replicating Kubikop's Peltier Module joule thief experiment and also trying an indoor solar panel experiment. There are so many things that I want to do and trying out different coil arrangements is just one of them.
    Lidmotor
      Hi Joit,
      I tested this a while back and here are my results: YouTube - Free Energy " One of a Kind Device " Claim Test
      Luc
      How about this circuit?
      The third coil must have high voltage multiplication. And the circuit driving the first coil do not have to be joule thief. The coil must have separate negative so car coil can not be used.
      I am not sure which third coil leg that must be connected to neon though.
      Nevermind, this circuit can only make a very dim light out of CFL.
      • Hi everyone,
        I would like for all to post your opinion of the video demo below and honestly tell me what you think of the test.
        Link to video: YouTube - RESONANCE EFFECTS FOR EVERYONE TO SHARE test 13
        The fist set of Scope shots and measurements below are of a bulb as load set to 3 volts RMS but fed directly from the Signal Generator.
        The next set of Scope shots and measurements are the same bulb as load set also at 3 volts RMS but fed by the secondary of the primary resonating coil to which is fed by the signal generator at the identical frequency.
        I am posting all this to get everyone's feedback. Is this test showing any advantages using resonance?
        Thanks for your time
        Luc
        • Feedback
          1) no, you're not wasting your time.
          2) your work to date has been very enlightening
          3) you don't seem to be able to close the loop with overunity systems, or even very very efficient ones.
          - I recommend reading the 'beating Lenz's law' thread, and the 'homework' peter lindemann set. I'm looking at electronics thru a whole different set of eyes now.
          After reading all the Depalma and tewari stuff, maybe go read a novel, whatever, let your subconscious process all the info.
          Then come back and see what is actually happening with electrons and 'magnetic' fields in your circuit.
          So, my feedback is, maybe there is a way to beat Lenz's law with your circuit, and greatly increase energy output..
          Also, I've shown that hard mechanical switching produces completely different effects to solid state circuitry..
          how big would a coil have to be (or capacitance etc) in an LC circuit for 12khz switching? Using a mechanical switch, What would happen then?
          Keep up the good work :-)
          Ps Here's some videos that show what I'm saying re switching
          Transistor different type of switch than mechanical switch
          YouTube - Inquorate 24 - slayer's big joule thief
          YouTube - Inquorate 26
          YouTube - purple neon circuit without transistor
          Mechanical switch, could be neo mag on switch contact, and motor in oil bath to reduce sparking, higher switch rates with bigger cogs..
          YouTube - regarding high speed mechanical switching
          • You wanna know what i think?
            I tell you what i think !! (said the ol Lady )
            Well, i read once, that this plastic insulated Wires have way lesser induction then the usual Wires. Not sure, what is true.
            Another thing, maybe you make 2 Coils, what do match better to eachother from the Size, and the Flux is crossing better when they are closer to eachother and you center them more.
            Or move them half apart, that the S-field from one Coil is at the N field from the other, and maybe lay them down.
            You can even try to align them to the N- Pole from earth (last rescue)
            Maybe its not a bad idea too, as in the Mtu?Thread, that you make a golden ratio of 1:1,61 for the Wires, but not sure, if it is about the Impedance or the Length of the Wires.
            And i am still not sure about, wich Coil is better in the Middle, the Big one or the small wired one.
            And you can maybe look for peak Points with your adjustable Cap, if you didnt do allready.
            But at last, Nice Video as allways
            • Comment
              • YouTube - How BEMF happen #1, LED version
                • Hi Luc,
                  Congratulations for your determination and hard working
                  Of course trying many different variations of circuit can bring you to lose the North, and to be kind of desapointed ...
                  Comes to my mind that the circuit must stay open in 'free energy' ...
                  So may be closing the loop might need a conversion step of the energy; for example using light on the powering circuit, and converting it to electricity through a solar panel; or using the energy produced to pulse coils to turn a motor, that mechanicaly turns an alternator ...
                  But of course many systems were working 'directly', harnessing the ZPE to light bulbs or heat stoves, or run motors ... so there are ways I'm sure.
                  For myself I was interrested by your open circuit where neon bulb was lighting with one wire only, in an open circuit configuration, like recently Dr Stiffler circuits were doing.
                  I'm very sorry not being able to help you in your tinkering, but for sure it's possible to have 'free energy', because many have done it in the past.
                  Zero Point Energy - Index - review of available information - MDG 2007
                  Also don't forget that you said that the effect was much more enhanced when bringing up the voltage !! So you might need few more volts to get a visible effect !
                  Keep on the work, and you could stop experimenting for a while, giving time to your mind to digest all the new data you just put in recently ...
                  Your previous scope shots showed the top of the sinwave above the top side of the square wave, and today they show the opposite, the top of the sinwave above the lower side of the square wave.
                  Sorry not being able to help you much,
                  good luck,
                  MDG
                  • Input
                    @gotoluc:
                    I personally believe that resonance is the attribute of these circuits that will enable the maximum energy output and eventually giving more output than input. You have brilliantly shown the potential with your videos, that i can only agree with most others upon, are a big inspiration.
                    As with all new fields in science there is formulas/equations yet to be put together that includes all relevant physical parameters.
                    Something like Energy = function of Inductance,Frequency, Voltage/Current/Resistance probably solved for the frequency E= df that can be calculated for Emax. I can imagine also trigonometric terms in it like sin, tan etc. where you are looking for the maximum amplitude of the function.
                    Any mathematicians here? It might even be possible that some prof. dr. dr. dr. has already invented such an equation, buried in some university library in some darn place
                    Does your measurement software allow Fourier analysis?
                    Maybe there is something to extract from those waveforms that the bare eye
                    can`t see (yet)?
                    EDIT: Have you tried to find out if your resonances match the equation w = SQR (1/LC - R^2/4L^2) at all?
                    Just a thought
                    Keep up the work, many people appreciate your research
                    Xenomorph
                    • Luc,
                      Dont lose hope my friend. Even if you quit right now, what can you take from this: You have learned a great deal about electronics, you have taught and inspired many. Not to bad if you ask me. Rectified makes a good point, tesla always credited his work being possible due to his education, you have to know what you are doing. Im currently back in school myself because i just dont know enough to really be able to figure this stuff out. As far as honest input for you, here are some things that come to mind for me:
                      Measurements- Your video shows the voltage but not the current, i dont know how you could measure current at that high of a frequency, maybe a current probe for the o scope. Once again, im no expert and to tell you the truth i havnt seen anyone that really seems to know how to calculate this stuff, or the ones that do arnt helping there. So you might just have to dig in and do some hard research.
                      Closing the loop- You mentioned something about not making enough power to keep the battery powered. Bedini has always said you cant charge the same battery you are running off of. So maybe charging a second battery and swapping it with the first every once in a while is the way to go.
                      Litz wire might make it more efficient too, but probably not vital at this point.
                      Anyways keep up the good work and dont lose heart
                      • Thank you to all who have posted All input will be considered.
                        I am not giving up but it may take more time than I thought to come up with a way to demonstrate extra energy.
                        Keep the suggestions coming and I will keep studying the effect.
                        Thanks for sharing
                        Luc
                        • i still got stuck at the Link what stephenafreter did give.
                          Really nice Page, Thank you Stephenafreter
                          I found even some of Resonant Coils, maybe it can inspire you a bit more Luc
                          Or the Caduceus/Smith Coil, which what i fall close in Love with it
                          Easy wounded for your Big Wire one.
                          • About open loop, I think an open loop one wire neon bulb lighter could be sold as efficient electronic rust preventer. That wire should be the electron releasing part (close the loop, and put diode to verify it, I did). In electrolysis the one that have electron surplus will release hydrogen. With the car body busy trying to make hydrogen, it won't rust as fast. Although maybe other metal not connected to that one wire will rust much faster.....
                            Yes, nice link stephenafreter .
                            I wish the caduceus coil test also include other coil type too, to see what make caduceus special.
                            • Hi Joit,
                              thanks for your post, encouraging words and links.
                              @everyone, you may want to look at the OU Forum topic as user Duff is making the power calculations and is trying to understand how the effect gets so efficient
                              Here is the link to his post and my additional information below his post: RESONANCE EFFECTS FOR EVERYONE TO SHARE
                              Luc
                              • Hi everyone,
                                I know things have been quiet for some days now but don't think the topic is dead. What we are doing at this time is re-evaluating the direction the research is going to take.
                                Once that has been done we will let you know by posting the new test results.
                                Thanks for all your support and interest.
                                Luc
