Originally posted by Joit
thanks for your positive comment
Using a soundcard to test one would have a frequency limit of about 25Khz. Also, RMS volts would be quite limited I think? The coil that I'm testing uses frequencies of 350Khz to 1.5Mhz depending of the load I have on the secondary.
These resonating circuits work well with a fixed resistive load but as soon as you change the load you need to re-tune both frequency and capacitance to get the circuit as efficient as possible again.
Thanks for the picture of Hans Coler's machine. We can see that he has put much work in achieving a geometric position of his resonating coils which I believe is another state of fine tuning. The SM TPU guys should know about this by now. I had 3 coils in series before I fried the H-Bridge DC Flip Flop circuit and it was at the point when I found that the position of each coil had an effect on each other, when I had the coils positioned to give out the max output that is when the circuit blew
Thanks for sharing
Luc
... now you are starting to see all the layers we have created form all this ignorance???... it doesn't just end there!... during all this play of illusion, some decided they should have more then the other (caused by ignorance that all is One) and over time we have refined this art of selfish greed and it is known to us today as capitalism!... we have even created an education system that teach you the more you have the more successful you are
... we are trading our Mother Earth for green pieces of paper
(aka money) to do what again
... we are a very sick bunch and need a serious reality check
... Jesus let man sacrifice his body to teach man many lessons... detachment of this illusionary world is One
... I'm sure many can think of other reasons... Jesus also said, "do as I do and the Kingdom of God will be yours" and what did Jesus or any of His incarnations do?... was he busy accumulating money or things? no!... He was Loving and Helping All and mostly those in need! which can only comes from a state of Oneness Awareness! which is the Real Truth and Knowledge. So why are we not following all these teachings?... ignorance! fueled by ignorance?... or maybe your illusion will create the illusion that all what Luc just wrote is his own illusionary state?... you decide
