Here is a link for some providers of propane conversion kits...
It does require a on board tank. However this is a alternate fuel that warrants investigations
From what is out there it is more common to find kits for carbureated models however more and more there will be Fuel Injections.
If its anything like appliances switching to natural gas from propane is simply changing a orifice
Its more complicated, and expensive than that.Particularly since conversions are typically to end up with the car being able to run on either gasoline or propane,with a simple switching system.Actually I've got a crazy idea. Ya know the system for running your car on compressed natural gas? Costs ya a couple of grand, for the compressor to install in your garage, and the high pressure "fuel tank" to install in your vehicle. And, if everyone converted, that would just raise the price of natural gas. But suppose you fed the compressor with a hose, (with suitable 1-way valves, etc. that drew methane gas from the SEWER system?After all, Natural gas IS methane! I've wanted to try this on a small scale with a generator, a hose, and a bong-type bubbler. Start it on gasoline, hook up the hose, shut off the gasoline, and see if it will keep running.Probably violating all sorts of safetry regs, unless there's a loophole in that no ones ever thought of/tried it, so they haven't made any rules against it! If you resisted the urge to 'tell the world' might just get away with it! After all, your not stealing. Sewage treatment plants think of the sewer gas as a nuisance. By the way, the way they eliminate it, safely, in many plants, is by feeding it to large, diesel engines.They use them to operate various pumps, etc. but the main reason they do it is its the SAFEST way to get rid of the gas.Why don't they feed it into the natural gas distribution system? Don't ask me!! Jim
