HHO used for METH Production?
  • HHO used for METH Production?
    This is news to me....I was told by a local NAzi party Member (Police) that having a HHO set-up the size of mine could be considered part of a Meth LAB.....
    Any ideas what he is taliking about? I know meth made certain ways can generate HHO but he was stating that people are bubbling HHO through the mix to speed up the Meth production?
    Any Ideas!!!
    I need to hear back on this asap!
    RedMeanie
    Stay clean,be nice
    Googled it, some people are having problems because buying quantities of Lye can set off alarms.
    Some may call me naive, but,...If you are not buying/using/selling/making meth, and you don't associte with those that do, You will probably be o.k.Oh, and don't call em Nazi's, don't even think it!(Not saying they can read minds, but they can definetly sense hostility, and since there life may depend on it, they are real good at that! Jim
      I believe that meth cannot be made without a Fractional Distiller set-up.... 10 times more complex than an electrolyzer. So tying hydroxy to it is rather tenuous and shouldn't hold up in court.
        use cash
        So if you buy lye for the electrolyzers, use cash and not credit cards, debit cards or checks.
          They do as they please when they please to do it with no regard for fact or truth. If they want to bust you and you dont have the cash for a GOOD attorney they usually will. We've all seen here what can be done to individuals when they stand out from the crowd
            Oh, I forgot
            I should have included growing pot, running a chopshop, or any other illegal activity.Actually, I would also avoid anything that makes it look like your trying to hide what your doing, so I would use a creditcard or check. In fact, I'd put what your doing right out on the front lawn, for everyone to see, figuratively if not literally!Make it easy for them to tell you aren't making Meth, so they can move on to those that are.Jim
              Hi Lee.
              The reason being is that part of the Meth process involves the extraction of the pseudo ephedrine from sinus pills. It also involves preforming an acid base at the end of the reaction to extract the METH. Both need an acid base. They actually put things in cough pills to stop the back yard chemist from extracting it. prob is, they are not back yarders and have found ways to stop the blockers.Some of them even soaked them in turps once to remove them, they have the blockers in the patents, things is, we don't know how bad these blocker chemicals are for your health.
              Any ways part of the extraction involves an acid base, where you will mix the pre treated pills in water and use a strong base like LYE to make it into a solid. You then are using a non polar solvent to extract the solid pre cursor into the solvent, but not the LYE/WATER.Once you get it to migrate into the non polar solvent (some even use Colman fuel) you then add water to it, (it will sit sperate to each other in two levels). Then you will drip hydrochloric acid into it, this drops the Meth and or precursor(ingredient out of the cough pills) into the water. You then put the water mix on low heat and wait till all evaporated.
              Then you will be using a keytone to make it into a hydrochloride salt (the METH, or the Sudo ephedrine from pills to make the meth. People use Acetone, so be weary of keeping that in front of that cop too
              So, its only the materials that the Meth cooks use to do an acid base. The bubbling could make a dumb ass cop think its a hydriotic acid set up (which is also used on one of the many processes).
              One engineer in know had his cold fusion lab raided and they thought it was a METH lab, he put his video on You tube.
              I hope people who consider taking Meth take note of the process i described, your putting that into your body.
              I know a bit about chemistry, so any Q's u have LEE let me know
              Ash
                some one sent me a wacky idea the other day of using ORMUS for super grass Ill think ill pass
