Over Voltage Safety Gap
Any circuit which includes a spark gap will have transient voltage spikes. At a high frequency of operation, the potential can build up on a capacitor in line with the spikes until the capacitor burns out, swells up, or even explodes. To prevent this hazzard, and the unnecessary replacement expence, it's a good idea to use a safety gap, to automatically short out the capacitor if a certain voltage is reached.
I'm using a 1uF cap from a microwave oven (MOC). When this cap is powered by a 6kV NST (Neon Sign Transformer), it will discharge across an eighth inch spark gap about once per second. (The cap is rated at 2100 VAC, but it will withstand more when it's DC.) However, it makes a very annoying, really loud "POW" each time. So I put an inductor in series with the cap, which is the secondary from a MO transformer (MOT). This converts the discharge into a small, quiet plasma spark which I've referred to all along as a Puff Spark. This is produced when a HV capacitor discharges into an inductor, with a spark gap in the circuit. I can now run this cap, and safety gap, off of a 12kV NST, without the capacitor burning out. If I use the cap with a CSET, the Tube's spark gap will have to be shorter than the safety gap.
This circuit uses a High Voltage capacitor.
By inertiatek at 2009-04-19
and at full speed it will give you a friction burn grabbing the shaft with your fingers and I don't mean a light touch where you're lightly touching the rotor, I'm talking about taking your fingers and squeezing down on the shaft. If there were 2 more coils on it for the other 2 magnets pulsing at the same time, forget about trying to stop it with your fingers - and this all with only 1 joule potential in the cap (1000v @ 2uf).
Anyway I have a question. Have you ran your high speed motor using batteries alone to charge the caps? I think I saw in the vids you posted, that you are using a Variac to charge the caps to power the motor and the circuit. If this is the case then I think there is a whole lot more work to be done. Alltho this method was probably one used by Grey on one of his many demo carts, we must not forget that he was planning on powering a automobile with at least one or more of the many motor variants he had built. Its impractical for us to think of a automobile powered by a motor that is powered by wall mains.
