I had, at one time, a website that showed the tests that the department of energy undertook in the 70's or 80's, in the desert. They used a water storage tank, similar to those found in most towns, surrounded it with stainless steel sheets, in a 360 degree circular pattern,all aimed at the tank to reflect and concentrate sunlight onto the tank. On top of this tank was a steam turbine hooked up to a generator. They claimed about 7 minuted after sunrise the temperature inside would cause enough pressure to start the turbine. I forget the KW output, but I vaguely remember it being capable of sustaining a amall town with electricity. Their problem was, they had a hard time furnishing this tank with water, as they didn't recycle their water. It would not be hard at all to build a smaller unit to supply power to our house, if enough water were available or we could design a way to recapture the water. If I can find the website again I will post it.
Stealth
Stealth
