e replica..it worked
hey guys,
I tried to make this, first with soda cans..got somewhat hot..then went to 2 paint cans ...kept the space less than a 1/8 inch,,it got too hot to touch. Used gear oil I had in the garage...Kept my large living room warm even when we got to -6.
I made the inside one, by cutting the paint can so it fit, had cut off the top of the orig outside paint can...
used the welding tube stuff..( good generic name)
anyway, put a tapered bolt on the top of the outer can when it was welded back on..added a fan blade( always cock eyed..but it made the difference I think
hooked it to a bicycle to get it going, very small gear on the top above the fan...connected to another gear..then to the bike gear
also road as fast as I can( age 56)..
but as the air /heat rose, turned the fan by itself.took about 55 minutes to get it hot..but wow..hot..
orig on piece of wood..bolted so it didn't take off..or knock over and burn something
redone so it's bolted to a firebrick
I could heat my house this way easily..but then again...
would not trust it if I'm not home to watch...
might want to try the 5 gallon or 10 gallon barrels..if I can find one w/o ridges...
any other ideas on how to turn the top w/o electricity?? Solar, but how??
janei
hey guys,
janei
Everything I could find about this style of heater was 2 drums with about 1/4 clearance between them. It all seemed like disinformation if you ask me. The heater I am running has NO emissions ans uses No fossil fuels not to mention you can run it on solar. Well to get to your question.. I maybe have around $300 into it so far. I have allot of other plans for other builds. I have learned allot so far with what works and what does not work. I would love to see the plans you have. I am posting all this info to see if anyone has ever really tried to build or want to build the heater. I am going to be using mine to not only heat my house in the winter but it will also heat my hot water and my pool and spa.
