Hello, ive been looking into the gray tube for a while now. But i have some problems figuring out how to chop the power on the high voltage side.
I have made a device that sort of looks like one, but the circuit is still far from where it needs to be. http://www.energeticforum.com/renewa...gray-tube.html
It sends a pulse(20 -30 kHz) into a TV-transformer, and whatever comes out goes to the tube. I need to chop AFTER the transformer.
Anyway, I'm trying to figure out how to do that, normal transistors burn out at a few hundreds of volts at best. So now i found this new component that might be able to do it, called a thyristor (SCR). Of wich i know little about and have little knowlege of its characteristics in this matter.
My plan was to have a 4kV power supply with a good capacitor for starters, and then through switching action of the thyristor discharging into the tube. The thyristor i want to control with a 555 timer and a small mosfet. Because I read that thyristors work on current, and 555's don't do current.
Would anyone care to explain me whether this is a viable construction? Or maybe i would be better off with a vacuum tube of some sort. Also do i need to use two 555 timers, so i can control the duty cycle?
Sorry if this sounds as a n00b question, I'm still learning :P
thanks for replying guys.
