temp drop in hho cell with meyers type circuit
  • temp drop in hho cell with meyers type circuit
    just ran a test today with a thermocouple probe installed in my cell. after switching on and running for around 15 mins the temp had not climbed at around the twenty minute mark i returned after answering the phone to find my temp display dropping i stood and watched it drop 1 degree a minute till it reached 11c at which point my motor driving the alternator connected to the cell overheated and cut out. i intend to fit a second probe for temp tomorrow and confirm what happened today. this was the longest i have run the setup and also the highest i've pushed the input frequency to the alternator. i checked the probe and it appears to be reading correctly and the cell was much cooler to the touch after running.
    i'm confused how this could be happening any ideas ?? there is no mention in meyers patents of this.
    (edit) start temp 23 Celsius (edit)
    Hi hhoexclusive
    Looks like you are getting always closer to Meyers Secret frequency ?!!
    What was your Amp. reading at the time of low temp?
    Do You Have a pictorial of your Setup?
    I have not used an Alternator yet.
    Does your Cell exhibit audible resonance? Can you hear it coming
    from the Cell ?
    professor
      there is a high pitched squeel that comes from somewhere due to the noise of the alternator and me being 70% deaf i'm not quite sure which component is making the noise. at the time the temp started to drop i was inputting 0.93 [email protected] into the alternator and getting out 39.5 volts ac 3 phase which is then fed through 3 diodes that all merge back into 1 wire. i dont use a diode on the neutral wire, could this be where my heat is escaping? through some kind of peltier effect moving heat up to my alternator and being dissipated through the windings. might post vid of it running on energetictube once i'm happy with it. i'm getting bloody obsessive compulsive with this thing will try a 3 foot long insulated tube cell this week to try boost gas production. if that works i'm all go to fit it to my car everything is there waiting for it.
