Im going to move my last post to a new thread called the dipole for futher discussion.
Question for Peter, Aaron, Jetijs, Rickoff, and other electronics wizards
Hi Darkwizard,
Thank you for your answers. As I mentioned to you I do not consider batteries as enviroment friendly devices so I do not get involved in circuits that are loaded by batteries and overunity manifests in discharging / charging rates, I can accept this happens, I did not say it does not work if you read my letters.
I am pleased you have got this knowledge and though it is up to you of course what you publish if you think people are not yet ready for it, then you may as well start a new thread and teach them, I am sure everyone will benefit from it.Originally posted by darkwizard View PostA motor/generator that i have on my head is overunity, but i think, that the people is not ready to this and i will keep my silence
Especially if you show correct replications too.
I have not seen it and I would like to read your explanation on it.Originally posted by darkwizard View PostDid you see 1985 generator? The dc motor with the alternator and 555 circuit.? What do you think it is?
Thanks, Gyula
If you don`t like battery, use solar panels and capacitors, instead; But if you don't have any input power how do you want to do a overunity machine.
On the Bedini monopole, input power is used only as a key to unlock the energy, to move a wheel with the energy from the vacuum and recover only a "small part" in the radiant/back emf form in the bridge rectifier in order to charge a secondary battery.
When the system self oscillates, it is capturing the radiant flow in order to trigger the transistor and the magnet passing amplifies the energy, that is why the oscilloscope shows an interference, that actually is amplifiying the radiant effect, but the torque is diminished and the machine stops if the primary battery doesn't have the sufficient charge/dipole.
Aether theories - Wikipedia, the free encyclopedia
Whittaker and the aether
Whittaker and the Aether
Einstein First Paper
Felix Ehrenhaf
Felix Ehrenhaft: Magnetic Current --- 9 articles
If anyone is interested in knowing what the energy is, check out the link for another side of the voltage/current world that is an inverse opposite component that isn't discussed much anywhere at all.
Magnetic current - not magnetic field, but magnetic current flowing over wires that causes a magnetic field to be 90 degree off the wires.
Anyway, it is very interesting and Rex Research has a great page with all those articles.
Also, for anyone that wants a super basic overview of a dipole and how it taps vacuum energy - kind of like a Bearden for Dummies as people have told me, Chapter 2 in my book The Quantum Key shows a simple explanation of the dipole and the first chapter is on the Aether. Available here: White Dragon Press | The Quantum Key | Aaron MurakamiSincerely,
THANKS FOR THE INFO AARON!! That is a very good information.
I think that the magnetic current , or pure aether flow, developes when the switch is On , and when electric current is fairly established the magnetic flow diminishes and the magnetic field is built. Therefore , there should be a short time when the total energy is on the highest level, and the correct pulse will crack the energy.
Darkwizard & Aaron.........
ok, you both have a pretty good understanding of the dipole, and radiant energy. Now, can you guys give me some feedback on my original questions?
Background
The bigger the "Inductor", the bigger the "Inductance", correct?
Example: On Page 25 of this document http://free-energy-info.co.uk/Newman1.pdf Joe Newman states that if we take an air coil of 40 gauge wire , 1000 feet long, and having a resistance of 1,049 ohms, then pulse a 100 Volt, 95 Milliamp current to it, that the resulting inductance would be .003 henries. No big deal, right?
But then he goes on to say, that if we take that same 100 Volt, 95 Milliamp current and put it into a much larger coil, say 5 gauge wire, measuring 3,348,000 feet, to EQUAL the EXACT same resistance as above of 1,049 ohms, that the inductance is now a phenomenal 8,000,000 times greater, or a whopping 25,700 Henries!
Question
Why aren't we just pulsing larger coils????
Why do we need motors, spinning magnets, spinning wheels, rotors, brushes, commutators, etc.
Wouldn't it be simpler just to pulse larger coils with a chip or oscillator?
Obviously, the example above with 3,348,000 feet of 5 gauge wire (and weighing 335,469 pounds) is a little extreme, but what about 10 pound coils, or 20 pound coils, or 50 pound coils?
What about wrapping some coils of wire around that car sitting in our driveway or garage that never moves. Would the iductance created be the equivilant of a much larger coil?
If any of this sounds viable, what would such a circuit look like? Anything like this?
Hi folks, hi bobo, its not likely although i would hope you get feedback but since what your saying works and is very simple although I think too many people are caught up chasing there tails in complexity, as I am as well at times, that we dont realize whats in front of us. Heres a simple idea to dispel charge time and any other inductance type variables, take 1lb of nichrome wire @ 50ohms and apply 12V and measure heat output then take 50lbs @ 50ohms @ 12V. I wonder which will make more heat for the same input hmmm. should be no charge time issues here just straight voltsXamps. If I had the extra cash I would try this.
I think that what you are saying works, but if you do work over a spinning wheel you take part of the energy that comes from the coil and the vacuum and translate it into free mechanical energy, no great torque but some free mechanical energy in order to move something. In your system, part of that energy is dissipated into the vacuum.
HiOriginally posted by darkwizard View Post
Can you please explain that more, that you think, Peoples are not ready yet for this?
Maybe in One Post, and not sproaded over 5, like your others.
And maybe in Facts, because all what you said till now are only links, and some parts from what you allready can read in here at the Forum, but nothing practical.Theorizer are like High Voltage. A lot hot Air with no Power behind but they are the dead of applied Work and Ideas.
