Click this link to view an interactive diagram showing the actual system used for generating and utilizing Hydrogen to supply all energy needs of a building which is located about a half hour's drive from where I live. Pathways to a Sustainable Future
Keep in mind that this is an actual system which is currently in use, and not just a concept. Some great ideas here for anyone to incorporate in a new or existing home. I plan to visit the building sometime in the next few weeks, and will take along a camera. If others are interested, I will gladly post many of the photos on my SkyDrive and provide a link to them in this thread.
Best to all,
Rick
Best to all,
Rick
The Hydrogen Shed, showing the Avalence hydrolizer cabinet.
An inside view of the cabinet displays the high pressure electrolyzer cells. A 4.5 kilowatt (kW) PV solar array on the rooftop of the CEE building is used to power the electrolyzer. The Avalence Hydrofiller 15 is designed to produce 15 standard cubic feet (scf) per hour, draws 2 kilowatts per hour of production, and uses 1/10 gallon of water per hour.
The 8 hydrogen storage tanks provide a total storage capacity of 2080 scf at a pressure of 2265 psi and are separated from the electrolyzer unit by a cement wall. Notice that the sides of the shed have spaced-apart vertical wood slats that allow floor to ceiling ventilation to the outdoors, thus preventing the possibility of hydrogen gas accumulation inside the shed if any leak were to develop.
Three Proton Exchange Membrane (PEM) hydrogen fuel cells, each rated at 1kw, are used to produce heat, water, and electricity from the stored hydrogen. Producing 1kW for an hour uses about 31.5 scf of hydrogen. Up to two cartridges can be removed from a unit for servicing, and the unit will still produce 800 watts. These fuel cells have an expected service life of 22,000 hours. Each fuel cell produces about 2/10 gallon of water per hour during use. Using the total of hydrogen stored, 14 gallons of pure water is produced. The fuel cells can convert about 75% of the energy stored in Hydrogen to electricity. The remainder is converted to heat. The fuel cells will operate between 140 and 200 degrees Farenheit once warmed up.
So the cost of such a system goes way down with Meyer's work added in. By the way where can I find those fuel cells and how much do they cost? Plus I would need their way of separating the hydrogen from the oxygen too. I don't know the life of an HICE being run 24/7 but that is noisy and has moving parts, but it will give people other options if the cost is too high for the hydrogen fuel cell. I found this on HICE:
