Hi everyone,
today I was playing around with a circuit recommended by YouTube user name: crob227 but I had no luck getting it to work as he recommended. So I took the circuit apart and started testing one component at a time and also added a load to the capacitor. A soon as I did this the load (bulb) started to oscillate. The circuit at that point also had a regular electrical dimmer for home use like crob227 had recommended to use in his circuit. By tuning the dimmer there is a point where the output at the capacitor is at the highest DC voltage to which is also at the point where the circuit is using the least amount of watts according to my new Kill A Watt power consumption meter.
Please have a look at the video which is very complete and post what you think of this simple circuit and effects.
Video: Capacitor Self Pulsing Circuit test 1 - Energetictube.com*-*Where technology goes LIVE!
Here is the data of the tests:
Bulb only on the 120vac 60hz grid:
Voltage to bulb: 121vac
Amps consumed: .54a
Watts consumed: 66w
Volt Amps: 66va
AC frequency: 59.9hz
Power Factor: 1.00
Bulb temperature: 290f. or 143c.
Bulb in circuit supplied by 120vac 60hz grid:
Voltage to circuit: 121vac
Amps consumed: 2.4a
Watts consumed: 37w
Volt Amps: 290va
Power Factor: 0.13
Bulb temperature: 275f. or 135c.
The Kill A Watt meter I used for testing also has a Kilowatt/hr. test which I did do also. When you plug in the meter it starts the internal clock at that moment, so I did the test with the bulb to the grid only and kept looking until the first digit appeared in the Killowatt/hr. display and looked at the clock and that took 8 minutes. I unplugged the meter to reset the clock and did the test with the bulb attached to the circuit and it took 15 minutes for the first digit to appear.
Thanks for looking.
Luc
Amps consumed: .54a
Watts consumed: 66w
Volt Amps: 66va
Power Factor: 1.00
Amps consumed: 2.4a
Watts consumed: 37w
Volt Amps: 290va
Power Factor: 0.13
Thanks for looking.
Luc
.. and I'll post my finding.
If I can buy a home electrical analogue meter
oh well... I can always use the one that comes with the home
