Sephiroth's Monopole Radiant Energizer
  • #16
    Anti climax
    Originally posted by Sephiroth View Post
    well, sorry for the anti climax guys, but it appears I can reproduce the effect by connecting the positive output to the charging battery but leaving the negative output detached while the front end is connected to earth (positive or negative side, doesn't matter)...
    Still think this is Tesla's radiant, but it isn't my set up that's causing it! oh well, back to the drawing board.
    Don't worry about it guy, I can't tell you about the times I had my batteries run low in my multimeter, and I was getting WONDERFUL charge rates. But when i replaced the batteries, cold hard reality hit me.....
    But to have the voltage flow both ways in the led... interesting, maybe back emf?
    See my experiments here...
    • #17
      the led is very interesting The effect is worth investigating but in its current configuration it doesn't charge the battery.
      Also interesting that it is only present when the front end is grounded.
      • #18
        led when grounded
        Nice, that bodes good things
        • #19
          Help!
          Hi Sephiroth and others.
          It seems that I saw this thread too late but curoius a little about it.
          Sephiroth can you please repost your schematics again I have not access to youtube.
          Many thanks in advance
          • #20
            wow... I completely forgot about this, lol. Seems like ages ago...
            I'm afraid it was a bit of an anti climax and the same effect could be manifested by just connecting the positive output to the battery and leaving the negative off... the flyback just formed a series of very high voltage spikes... I can probably fish the schematic out but as I said, a basic bedini circuit shows the same effects if you disconnect the negative charging output.
            • #21
              Thanks Sephiroth
              I have another question too. Assume I want to replicate Tesla's works and phenomena like breezing ether or hot stream of it or ... I do mean for having an ultra high speed switching which transistor or Ultra high switching facility needed( any transistor name or mark). I am thinking that by which tools can I have an ultra fast switching like Tesla did and got those strange phenomena. I am familiar with the concept of RE. I think Tesla's ultra high frequency AC generator made for his magnetic quenching spark gap to make ultra fast switching. You got true results about the diode, I got the same result like yours when I changed the lightening diode polarity I got the same results!!
              I must say that for knowing how RE works you don't need a SG motor!! It is as damn simple as charging a coil and let it collapse through a diod for blocking the electron current. I got result without even relays or transistors you can close the circuit manually and open it manually you can lighten a diode in this fashion very simple! A bout your cold breeze phenomenon you were right too!!
              I owe my knowledge on RE to AAron , Peter, Bedini and Jerry Vassilatos nice book(the secret of cold...) Thanks to them All and thank you Sephiroth for posting your experiments.
              Excuse me for my English.
              Leedskalnin
