I was reading on internet about batteries I've learned this:
Lead Acid: There is three types basically, car batteries lead acid, lead acid deep cycle, and gel.
Car battery: gives powerfull high amp, for short time, but if discharges lower than 11.9 volts plates can be sulfated so much, and loss total capacity on recharge.
Depp Cycle: batteries, for ups, golf car etc, are batteries can be discharged to 10.2 volts for example, theirs plates are more width and support for long time this high dischargers and recharger cycles.
Gel Acid: are good for home, no leak acid and no gas and relatively good deep cycle.
NiCad: this batteries are LOW RESISTENCE INTERNAL and my question is this; are good for tesla switch application?. When is getting bad, recharge fast but discharge very fast, called memory effect. CADMIUM is toxic.
NiMH: better than NiCad, and more ampH per size, suffering less memory effect but less charging efficiency.
LiION: very good, but high cost, 100% efficiency for in recharge.
INTERNAL RESISTANCE IS LIKE BEDINI CALL MATCHING IMPENDANCE ON LOAD? LOW INTERNAL RESISTENCE ON BATTERY DISCHARGED COULD BE FUNDAMENTAL FOR TESLA SWITCH
) starter battery but after only three overnight cycles on the charger it worked again. So based on his and my experience with this technology, the more circuits you have the greater the response will be, from the battery.
He apparently found a bigger battery to test out, 190Ah or somthing. Should be a good "real world" test.
