  • Originally posted by nat1971a View Post
    Latest circuit of the hybrid tesla wireless radiant energy transmission / edwin gray system
    Nat where is the postive of the second battery going? and the second ignition coil spark gap. are theres connected.
    I cant beleave it, your breaking the postive and negative of the batterys its what i was doing with the reed switch along time ago but you work it out Nat Nice One
    • Originally posted by Burned_NE2 View Post
      Hi All
      Not to throw a damper on the experiment but.....
      Been following this for awhile and after seeing the DVM (Digital Volt Meter) readings in the video going crazy I thought I'd chime in. I have seen this many times in my own experiments with spark gaps creating havoc on the DVM but with no extra gains in charge to the batteries. This has been described as radio frequency interference by some people which I would tend to agree with. I have seen this by placing an unconnected DVM close to the spark gap with the same effect.
      Try using an analog meter instead of a digital meter, you will probably see a different reading.
      Keep picking at it, who knows you might be onto something
      Paul
      I aggree Paul the DVM are crap but the fact its reads anythin makes me smile
      • @bodkins
        the positive on the battery is connected to nowhere as illustrated....whether it needs to be in proximity to the receiver coil...i dont know
        the spark gap you refer to is connected as illustrated to no where.....whether it needs to be in proximity to the coils..i dont know
        @anyone
        care to explain the voltage in the system while not running....? this may have been when i connected the insulated plate to the transmitter sphere via the insulation....might try that again to isolate what is causing it...
        previously the volt meter was reading nothing until i added grays conversion tube....i think that was why i was getting strange behaviour in the beginning as i had it in the circuit and didnt realise as it was from a previous experiment....then when i added another conversion tube to the receiver circuit...i was measuring something...then spark gap starting happening on its own......then the meter went crazy
        • Lidmotor's Rheostat and Theremart's turnlight signal bulb
          Hello,
          I would like to know if anyone could explain me what exactly is an Lidmotor's rheostat and the Theremart's turnlight signal bulb. Also how they are connected and their values.
          Thanks!
          Heres the revised circuit that i have been working from
          Nat
          • Nat what about stepping it back down on the receiver side with another ignition coil?
            also about the spark gap read this, i think the spark feed the spheres
            Corona discharge - Wikipedia, the free encyclopedia
            (A corona is a process by which a current, perhaps sustained, develops from an electrode with a high potential in a neutral fluid, usually air, by ionizing that fluid so as to create a plasma around the electrode. The ions generated eventually pass charge to nearby areas of lower potential, or recombine to form neutral gas molecules.)
            and the bit on Air ionisers perhaps benefiting health(negative sparks)
            Air ioniser - Wikipedia, the free encyclopedia
            maybe bigger things we can do with this
            • @bodkins,
              interesting idea about stepping it down again....will look into that. that makes sense...should balance the two systems again
              cheers
              nat
              • Originally posted by Pcurrius View Post
                Hello,
                Thanks!
                Pcurris--
                The info on the rheostat and the light bulb are back on page 11 of this thread. Basically they serve as ballast resistors to control the energy flow out of the source battery. It is a crude way that we found worked to help control the 3amp draw of the early circuit. Watch out for heat on the rheostat. A heat sink is a must---or turn off your smoke detector and break out the marshmellows.
                Bodkins and Nat,
                Check out Allcanadian's latest thread called "Free energy is here". The circuit and text description are all Tesla stuff. This is starting to make sense to me. Ossie Callanan also just showed me a circuit that is similar (based on Stiffler's and Bedini's work). It is all about getting an induction circuit into resonance. Do it right and-- out comes you know what.
                Lidmotor
                • cool i will check it out...thanks lidmotor
                  • Printed it allreally Lidmotor, I new resonance was the key, I posted links to resonance video earlyer in the thread, Ancient Egypt Pyramids are giant acoustic resonators NOT tombs. Incas had the key too all ancient used acoustic resonance.
                    Look at the shapes in this video and look at ancient symbol
                    YouTube - Resonantie
                    and this one is the soup of life
                    YouTube - Amazing Liquid
                      @bodkins,
                      cheers
                      nat
                      And some caps!
                      YouTube - solar powered tesla coil
                      At 1.58 minutes pause it, I think he has a cap on the receiver.
                      Resonance=Balance
                      @Braden Got the Coils
                      • Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
                        • Aromaz
                          • Welcome!!!
                            burn out?....i'm not sleeping at least 3 days a week at the moment!!!
                            • First of all welcome. We all started out as learners in the field with lots of questions, so never be afraid to ask a question.
                              Peter has always said read through all posts, do all experiments and try to confirm them twice, you will quickly build a solid knowledge of what you are doing and the rest will become easy. I like listening to music, while I am doing my experiments, but as of late my format will be changing. You will have a little time to catch up to speed, because my new releases will be a few months from now. It will be much more advanced but still easy to build and off the shelve. My goal is self-sustaining energy independence. But it will be accomplished in steps. You are among the most pleasant, generous group you will probably encounter anywhere, without exception all contribute as they can and you will find no better group. Thats why I try to release my work here. There are too many people to list but suffice it to say Aaron and Peter, lidmotor, bodkins,nat,ashweth I can go on and on. They are the best and will help you when they can. So have fun and share. When you run into things that we might have not seen or maybe missed, Glad to have you aboard.
                              Nikola Tesla
                              http://www.imhotepslab.com
                              • YouTube - TESLA'S RADIANT ENERGY WIRELESS TRANSMISSION - UPDATE 15
                                tesla receiver charges up to 600v without the system running.....then i had to go to work....
