  • Aromaz
    Dynamic Resonant Energy
    P.S. Frequency the same theough out the system, though wave form picked up with scope probe near coil/transistors are the original Galloping Kangaroo, but the wave form at the fluorecent tube is a nice steady wave form - this is throughout the complete system connected onto the copper coil arounf the Fl/Tube
  • Aromaz
    All up and going.
    At last all video's I made for public release are up and running.
    Forgot which I posted here already and short on time to go back reading, thus here they are.
    # 013 - Personal conclusion and some ideas.
    # 014 - Advancement of the Dynamic Resoant Energy
    # 015 - Have to watch #013 first, then this one:
    Show and prove practically - for the first time ever, I believe - how and why the multi meters are useless with Radiant Energy.
    Below are a few photos, but first you will need to watch video # 014 to be able to understand these photos. Applicable to my posting #1465 on previous page.
    A: View of tube with only HV connected, nothing on the other side of the fluorecent tube. Note, there are no transmitters or receivers i.e. wireless transfers.
    B: Lights in full bloom, same chair, same corner 5m away from system
    c: Scope shot. Have the voltages + and - as well as frequency now very steady. Nice wave form and no visible spikes - on scope but fq slight audio-able........ Excellent reactor transfer of energy.
    Amp meter? On battery Positive reads 0.08 MILLI AMP. Can we believe that one? YES! It is the only closed loop conductor circuit - Battery - Transistors - Coil - Battery
    Now I am waiting to hear what some of you will find and contribute.
    PLEASE GIVE ME NICE PRESENT - 4 Dec in form of new discoveries on this forum; with or without my DRE!
  • ren
    Originally posted by mlurye View Post
    Here is my schema. I was using microwave transformer. Transistors are not heating up. And CFL is bright.
    Good to see someone esle using something besides an ignition coil. Nice feed back arrangement.
    I found that the lower frequencies provided more light with the mot, but with the toroidal higher frequencies gave me more light.
  • Tishatang
    Yeah i highly recommend reading lost science ....man there is some major jig saw pieces of the puzzle in there......
    Borderlands Science is reprinting LOST SCIENCE and other Gerry Vassilatos books see here:
    Gerry Vassilatos
    I guess they realized there was a market with used prices going so high?
    tishatang
  • RealityMaker
    Enforce it
    I've seen Peter's tests at his shop with the CFL circuits based on Imhotep's designs. I've done quite a few tests myself with other applications.
    This is what I'm intuiting will come from here.
    A major part of a circuit that will act as a radiant capacitor charger to charge caps at 4-5kv an from 4-12uf for the HV cap on a Gray Tube circuit. It will be a hybrid from some of the circuits from the water sparkplug thread. Anyway, I have immovable faith in ALL of you involved with the developments here at Energetic Forum.
    The radiant cap charger is the CHOICE radiant cap charger on this diagram:
    http://www.energeticforum.com/36766-post52.html in the Gray Tube Replication thread.
    Number of such reactors (for example 6 as several articles mention were used in Tesla's car) in parallel or cross connection, to form contours in one circuit to put usefull load on it. BRAVO Aromaz!!! Bravo Aaron! Seems we will have working
  • Inquorate
    @ Aromaz
    Thanks for advice. Off I go for more fiddling..
  • Aromaz
    Originally posted by Inquorate View Post
    I can not see video too clearly. However would suggest two things to start with:
    A: Remove the resistor and eneon between the poles of the coil.
    B: remove the complete circuit away from the coil. Looks neat and tidy up there. but it is very likely the coil is affecting your 2222. Is this 2N2222A ?
    Check the 2222 for correcth collector and Emitter connection. Do not trust RadioShack. Also make sure your slave transistors are correctly matched.
    Try again?
  • Aaron
    HV radiant charger
  • Inquorate
    Humble pie.
    Little help..
    YouTube - Inquorate 10
  • Bodkins
    Thanks Arron thats brillant good for make and break switching i now see what the relay charger can be use for
    @Nat i going forward and sort on time i was just playing around with the brick.
  • Aromaz
    Advancement
    YouTube is doing maintenance, so my video #014 will only go life later. In the mean time I would like to do some explaining here. As said before, I had a dream last night where I was giving a lecture about DRE - and amongst two other items I described this phenomenon you will see in Video #014.
    Now, it took me about 25 minutes to prepare for these changes - and most of that spent on winding a bi-filar coil around the tube. I did the same experiment in 3 versions and made two of them on video - it all took me less than 1 hour. The video, editing and uploading is taking than 2 hours.
    FOR THOSE WHO DID NOT DO THE REAL EXPERIMENTS:
    I am not going to waste time on answering question and helping people with this - unless they have gone through the sequence we have started on this forum - from # 1 to the last page. I did it; you can do it. It took me nearly three weeks - and I learned very much. Thus everyone can do the same. I am not here to spoon feed you, you have to do your own work. Unless you experiment - ..........
    We (humans) took electricity and made lights, then we grew up and made motors,then we learned how to make electricity from turning motors. Now we can see how to make electricity from spce and how to turn that into light. Please note: These are all in addition to what I said on Video #013 and postings above. There is so much more for us to learn - and I will need you to help me -please ?
    DETAILS OF ADVANCEMENT:NOTE:
  • Aromaz
    Be careful !!
    Very nicely done. You have jumped some of my later video's - but important to step back and first get this under control. Believe me it will become very dangerous and MV coil generates a heck of lot of energy on the outpus. Same is valid for series flybacks.
  • nat1971a
    @bodkins
    can u post some video of the brick experiment
    Nat
  • nat1971a
    @bodkins,
    Can you post a circuit diagram of the one with the brick in it
    cheers
    Nat
  • mlurye
