I have a growing fascintation with these things as of lately. Watching some of the videos out there and searching for already documented info is somewhat challenging.
The videos often show incomplete motor or WIPs of motors but rarely do you see somthing that is proof that you can harness the power from magnets and make static magnets do real work.
Over about the last 2 months since the Howard Johnson Video came out I have been playing around with several PMM devices.
I have had pretty good success with them. I am not going to show all the things I have built but I am going to try to lay down a small foundation for someone else to get started.
I dont want to make claims that anything I am showing is 100% mine. I used what I seen and read, to formulate my positions and devices.
The primary device I want to discuss is a small Magnetic Track that I built to played with for about a week. Similiar to Howard Johnsons train tracks. The formula is also outlined in his book.
YouTube - Magnetic Track
Its not pretty but basically its very simple. I have some 2 x 1 x 0.5 " ceramic magnets glued down to board. (The video is dark) The magnets are arranged at 45 Deg or so to the track wall and then set in one by one in front of each with aligning poles. North is set toward the open "V". Each side of the rail has NORTH pointing in. See pic if I confused ya.
Now this is not spectacular in itself but it proves that magnets can do work in a linear fashion. Once engaged the magnet pulls the other magnets down the track. They produce Torque that can be measured. The movement of weight from point A to point B can be calculated into horsepower. Hence you have a motor, whether usefull or not. If not good for anything else it will make people wonder or scrath there heads.
But further testing of different magnets show more positive results.
This Motor is consistant with a straight line. A begining and end. A circle doesn't have this problem. Circular magnets can be shaped so in the same fashion with each angling in a different direction. If the magnets are big enough they will form the Vortex that shows up, in the device shown above.
Vortex??? Whats about the device is a vortex. Vortex - Wikipedia, the free encyclopedia
I'll tell ya. The diagrams in the following picture are what I'll refer to.
Diagram #1
This shows a common magnets under normal conditions from the side. From what I understand this is NOT the conventional view of a magnetic feild. But this is the way a magnet works.
Both North and South have a dipole. For explaination purposes I'll refer to the North Positive (Left Vortex) and North Negative (Right Vortex). South Positive (Left) South Negetive(Right). This is just the theory I use to put my devices together. And it works. So far....
Diagram #2 Show what happens when we rotate a magnet 45 degrees. The positive of the North pole and the negative of the South pole then are rotating on a horizontal plane. And the other 2 are rotating on a vertical plane.
Now we should start to see how this can work for us. We know Ferrous materials will weaken the feild stregnth of a magnet, But not STOP them completly. So we don't want to use that to conserve half the the dipole. We want to use another dipole.
Again I gotta note this is not new, Howard Johnson said it in his book.
A Magnetic feild can be SHORTED out with another magnet.
Diagram # 4 shows how to do this and what happens when we do it. And in my device that was in the movie this is exactly what happens. We short out the Negative North with the Positive South. And we continue it through several magnets. This allows for (in this device) the Positive North from each set of magnets to MOTOR in the same direction. Hopefully you can see how a NORTH magnet could get pulled into this and dragged along until it ends. The feild of photons from both the Driver and driven magnets interlock and basically have the same motion characteristics of Tennis Ball Launcher. And they form a Vortex.
A very simple means of creating linear motion from static magnets.
Now thats great if all you wanna do is drag some magnet from one end to another. Think of the uses it could contribute to society. A finger smasher. Thats by best device I can come up with.....
Again I have to say this very same effect can be acheived with round magnets, in a circle. The trick is finding the right sized magnet to drive.
OR....
You can cut magnets. EI Diagram #3
Although this takes good tools and some knowledge of the materials and cutting, the biggest worry you have is creating to much heat while cutting them. A wet tile saw filled with Ice water and a metal diamond blade can do alot in this department. MAgnetic shavings can be removed from the blade with another big magnet.
Think about it... If you have a magnetized cube and you cut four corners at 45 deg, off the cube to make a smaller cube then your poles will run from corner to corner. Or you cut 2 corners off, rather wide then 2 corners rather small then you end up with a small flat plate. These plates together side to side will give you the same effect as the MagTrack device shown earlier and can be done with powerful magnets.
Shapes can be formed with soft magnetic materials (Fridge magnets) between magnets. The feilds from these magnets won't get in the way of the bigger magnets. You have already seen Diagram#5.
If you take a fridge magnet and cut slices progresivly larger every time then stack them they make wedges. Or they can simple be compresed on one end and not the other. This might hurt the feild but it still can be used.
I'll leave you with this image of a partial assembly.
Now I know about the scepticism thing and I can't blame people for not wanting to except a movie of something, but this a foundation of material that works.
It may not, in the long run, produce viable free energy. But it does produce.
Build the simple one shown in the movie. It costs about 20 bucks and can show you alot. Then if you still don't think its possible to have a permanent magnetic motor, post it. And i'll show you a little more.
Hopefully someone will try it out and see what I see in it.
Be careful.
Again I don't want to take any credit for this, I just wanted to show people it works.
Matt
Diagram #1
OR....
Be careful.
Matt
