Addition of Mg Ribbon
I noticed the Mg Ribbon I have and garbed couple rolls and the shovel.
Hooked Pos to the 8' Copper Grounding rod
Hooked Neg to Mg 12"x1' rod 5' away = 1.3V - .36mA down to .33mA
Buried Mg Ribbon aprox. 3" deep in south direction
10' mG ribbon alone = 1.65V - .74mA DT .72mA
Ribbon & Rod = 1.6V - .72mA DT .7mA
25' of Rib = 1.69V - ? DT .85mA
Rod & Rib = 1.66V - ? DT .8mA
40' of Rib = 1.69V - .82mA DT .77mA
Rod & Rib = 1.64V - .88mA DT .76mA
Seamed to go down which didn't make me happy
At this point I thought to add everything in the area - So
40' Ribbon & 5'distant Mg Rod & 4Mg Rods 1'distant in star = ALL
To both copper Grnd rod & Carbon star as Positive = 1.6V - ? DT 1.56mA
To the A-hole star Carbons = 1.58V - ? DT 1.62mA (Better then W/Grnd Rod)
more mA so decided to just use Carbon Star for Positive
65' to Carbon star - Neg-ALL = 1.636V - 1.96mA DT 1.7mA
65' to Carbon star Neg-Rib only = Not on notes
80' to Carbon star Neg-ALL = 1.65V - 1.89mA DT 1.68mA
80' to Carbon star Neg-Rib only = 1.774V - 1.71mA DT 1.5mA
94' to Carbon star Neg-ALL = 1.54V - 1.96mA DT 1.65mA
94' to Carbon star Neg-Rib only = 1.7V - 1,6mA DT 1.44mA
Added Mg 1'x1" Rod at end of ribbon
94' to Carbon star Neg-ALL = 1.58V - 2.2mA DT 1.7mA
94' to Carbon star Neg-Rib only = 1.72mA DT 1.45mA
Volt's less but Amp's at load better with all Neg elements I can use.
Need to add Ground Rod and try (Tomorrow)
Also want to add some ribbon off in an E-W direction
and a spiral ring around a tree in the roots
Just to see what can be picked up
Then theirs the poss wire to run
I've got no more North direction (Less I sneak over the fence just for a test run then remove it) its a vacant lot and I know who owns it so it'll be OK
But I will be running to the East with a 12 gage wire and an 18 gage in the same hole about 2" apart 3" deep maybe
Might need to do test with deeper wire but boy that would be some work
(If I ever get a new motor for that trencher I have - It will dig a 2' deep trench)
FrznWtr
FrznWtr
