Interesting idea Vortex. I really like the idea of using activated carbon, i had been looking for a cheap source of carbon for the electrode. I wonder how well it conducts, some carbons i have tested are very poor, graphitezed carbons seem to work very well but not the powdered stuff. I would think that the salt would erode the electrodes and make it unusable over time, like a battery sulfating
but, i dont know. Im betting that it would be much easier to get good results with the salt, but long term constant use will cause more problems than the earth battery.
The thing i like about just using the earth or regular water is that there is no electrolyte maintenance. Water naturally gathers ions from the environment, distilled (deionized) water will go right back to normal if you leave it sitting out. And the earth of course is a huge reservoir of energy. With the medium being recharged for free i think the only problem beyond that is finding the right electrode material that requires the least maintenance and cleaning, carbon is probably a great place to start. Once that is figured out, its just a matter of scaling it up to a size thats actually useful. Thats my take on it at least
Thanks for the carbon idea, ill have to give it a try.
but, i dont know. Im betting that it would be much easier to get good results with the salt, but long term constant use will cause more problems than the earth battery.The thing i like about just using the earth or regular water is that there is no electrolyte maintenance. Water naturally gathers ions from the environment, distilled (deionized) water will go right back to normal if you leave it sitting out. And the earth of course is a huge reservoir of energy. With the medium being recharged for free i think the only problem beyond that is finding the right electrode material that requires the least maintenance and cleaning, carbon is probably a great place to start. Once that is figured out, its just a matter of scaling it up to a size thats actually useful. Thats my take on it at least
. So yes i can confirm you results vortex. However there is one big issue i have with it; it has a very high resistance. At best i saw 2 M ohm across the piece, thats very high. I suspect trying to pull much amperage from something with such high resistance is not going to work very well. But more tests should be done. It may just be because Im a newbie to charcoal making.
I chose zinc and carbon because i thought i would not have any corrosion problems with them. Has anyone else noticed anything on their zinc plate? It may have just been a poorly galvanized piece so ill have to do some more tests.
or at least not as fast as i witnessed it. Good thinking with the carbon\carbon cell. Im just thinking that we know the earth has an enormous amount of energy and there has to be a way to tap it without destroying the plates
