no load generators...
Hi Peter
I have one question about the no-Back-EMF-Motor
Would it be possible to run it like a electric coil-gun?
Below I give two websites on the basics on how coil-guns function, for those, who haven’t heard about it or might need more detailed info.
You will see that it is very similar to the no-back-EMF-Motor.
Theory
Experiments - Thyristor Fired Coilgun
The piston might need to be a bit shorter than what you show in one of your videos, so it can accelerate nicely in the coil and won’t get stuck. These coil-guns produce tremendous powers. If now this projectile would work like a kind of air-spring it theoretically should make a nice motor?! The piston would compress the air together, with tremendous power, the compressed air acts like a spring and presses the piston back into its original position. Springs in common show a weird effect, physics can not really explain. If it discharges or releases the force a two to three times stronger force will result, which was invested in the compressing of the spring. Naudin made good experiments with springs one can see them on his website, with OU effects. This would give a nice interaction, and the invested energy would be recovered in this way.
But what occupies me much more is if the coils could not be directly fed with dielectricity and thereby built up a magnetic field in the coil, which after the collapse would invert into a dielectric field, which could be caught in a capacitor again.
Lighty and I in the past two years did experiments with positive and negative dielectric spikes and could observe very interesting effects in the coils. Although there almost was no current going into the coils a striking effect occurs on the magnetic fields and the magnet jumps under the influence of this force. On the other hand magnetic materials like iron or mu-metals react almost not at all, or the reaction is very weak.
If a magnetic projectile would be taken now, instead of an iron-piston one would need very little energy to run it.
If I remember well, did the inventor Bob Teal use his invention for air compressors? Could it be he simply had an air-spring which could recover its energy?
Best of greetings,
Shad
Hi Peter
Theory
Best of greetings,
Shad
