Lighty, I doubt that prewinding the coil is possible with my design:
The end part of each pole is wider, so I would not be able to get the coil on the pole and If i fill the thinner part of the pole so that the whole pole is as thick as the thickest part, I would lose much space. I will better wind all the coils by hand, after all there will be only 30 turns on each coil, that should not be too hard
Nevertheless everything seems to work fine. I assembled the motor and turned the rotor to a "firing" position, then I took one series coil leads and just hit the battery terminals with them, the motor just took off (at least as far as it could without proper timing. My bearings have considerable friction and I was afraid that this would be a problem, because the rotor wont spin freely even for a little while if I spun it with hand. But when I made this one power pulse, the rotor made whole three or four revolutions. For now it seems that the motor has a lot of torque at least as far as I can tell with this simple test. Now I will need to work on the timing circuit. I will draw it tomorrow and post here so you can comment and maybe suggest something. So that is it for now.
