Right
Lighty,
Yes, the idea is to block the energy from going back to the battery. Why? Putting the energy back on to the RUN battery is the same as throwing the energy away, because the battery cannot be charged and discharged at the same time. In the arrangement I am suggesting, the capacitor acts as a buffer stage. Its voltage will never drop below the battery voltage, but it may rise above the battery voltage whenever the return energy pulse arrives.
The isolated output coils already have their respective diodes associated with them to block any current flows during the input phase, so they only allow current to flow during the magnetic field collapse phase. When you collect the output energy from the same winding as the input, the output current is reversed and cannot be applied back to the front of the circuit without producing a short circuit in the system. By collecting the output on an isolated winding, the problems associated with this current being in the opposite direction are negated, so the energy may be applied directly back to the front of the circuit with no other complications.
This frees the system from needing a second battery to receive the recovered energy.
The idea is to optimize the circuit conditions for this recovery mode, so the motor can be run by simply replacing that fraction of the energy that is NOT recovered. When this circuitry is coupled with a mechanical section with a very small air-gap, so that the mechanical torque production is high, the probability of running the COP>1 is also very high.
Peter
Peter
Anyway, here is the picture of the whole circuit that I am indending to use:
