Peter,
I resoldered everything on a new soldering plate. I decreased tha optotrigger bridge resistance to 500 Ohm. Now I ran the motor with only one transistor at a time, to verify that each one of them has the same performance. First transistor got the RPM's up to 480. The second transistor performed the same. The third transistor was a little weaker and got the RPM's to 475.5 (4.5 RPM's less than other two). Now I connected them in parallel, here are the results:
# of transistors | Current draw |RPM's
1_______________0,55A_______480
2_______________0,55A_______527
3_______________0,55A_______538
Does this mean I need to remove some more turns from the startor coil?
Thank you,
Jetijs
Thank you,
Jetijs
The first time I was afraid that the whole thing will fly away
Thank you for your understanding.
