The center post on the fans I took apart is the answer, Cut off the top 1/8th of an inch and the circuit and coils pull off
Strange
Hello to All,
I have a question.
I did replicate the Imhotep radiant charger a while back and been using it often. So I have a badly sulfated riding lawnmower battery with standing voltage of 0.0. Connected it to the Imhotep charger for 4 days . The voltage went up to 11.67 standing volts. I did test it with (2)DC 50 watt bulbs and the voltage dropped slowly then returned slowly and this is a good sign.
I placed it on a Black and Decker smart charger for 5 minutes, but it read "FO3" this is code for open cell. I reached over and pulled the plug out of the wall 110 ac with the charger still connected to the battery. The B&D kept running for 2 minutes and the battery voltage dropped to 11.61 volts. Then the charger finally shut off and the battery voltage returned to 11.67 volts.
What?? Is this normal? I set a marine 100 amp hour 12.07 volt battery behind the B&D charger. Connected the charged for 5 minutes. Then pulled the plug with the charger still connected, but, it stopped immediately as it should.
Had to try this several times and got the same results.
Is this normal for a Imhotep charged battery?
thanks,
wantomake
wow. somebody still here.
Thanks Resystance,Originally posted by resystance View PostWorks for me!
Was hoping for an answer. Did this happen to you? If yes, what did your battery charger do?
If no interest with this I guess will use the battery somewhere. But was hoping I had something different.
Anyway,
wantomake
ive had some batteries that continued charging after they were removed. they would continue charging until they burst their seals. and as long as i wasnt drawing current off of them they would destroy themselves. ive also had a battery that is still giving off power and has not been charged since 2008. if u go all the way back in this thread you will find me mentioning in 2008 a clock that continues to run to this day with no signs of running out of energy. aaron had thought it had become an electret. so yes i have experienced some batteries that continue to produce energy. i dont know under what circumstances or what fan i used at the time so i dont know if i can reproduce those same resultsOriginally posted by wantomake View PostHello to All,
I have a question.
thanks,
wantomake
there were many types of fans, each one with their own geometry of coil windings. most that ive encountered have dual windings and the post that has two windings connected to it that you separate are hooked up on the original circuitry to the positive end of the source battery. but once u separate them and check cont, between the 4 wires you will find in most cases continuity between 2 of the wires and that will be 1 coil and continuity between the other two remaining ones will become your other coil. it will usually only work one way so if your unit does to work u can try swapping the wires on either the pulse output coil or the trigger coil and get it to work.Originally posted by Hrothgar View PostAre the negatives on the stator the ones with the 2 wires soldered to one post?
Thanks for your inspiration
Thanks so much,Originally posted by **~Imhotep~** View Postive had some batteries that continued charging after they were removed. they would continue charging until they burst their seals. and as long as i wasnt drawing current off of them they would destroy themselves. ive also had a battery that is still giving off power and has not been charged since 2008. if u go all the way back in this thread you will find me mentioning in 2008 a clock that continues to run to this day with no signs of running out of energy. aaron had thought it had become an electret. so yes i have experienced some batteries that continue to produce energy. i dont know under what circumstances or what fan i used at the time so i dont know if i can reproduce those same results
That is strangest effect I've seen from any battery. I only had it on the fan radiant charger for 4 days and it's an old battery(dated 2009). So I'm leaving very soon for Japan and thought to leave it charging for a week. Don't worry my son-in-law will disconnect it for me. Should I charge longer than a week?
We are trying to learn more about crystallizing and drawing energy from aether on the "3 Battery Generating System" thread. (Aaron: hope ok to mention other threads on a different thread.) Thanks I'll research back and find where you talk about the clock.
As a student and fan of all the good teachers here on energeticforum, your help and open heart is greatly appreciated.
wantomake
Charge length is depending on the battery. It is always important to closely monitor any battery on the charger because you can never predict how it will react. We have exploded button cells by just leaving them on for just 40 seconds. And a few D size batteries leave quite a mess when left overnight. 12volts I have left on for over a week with no problems. it actually kept decrystalizing car batteries. Always wear protection over your eyes and if you leave it on for a long period of time make sure there is someone to keep a eye on it. good luckOriginally posted by wantomake View PostThanks so much,
wantomake
Always safety first
Imhotep,
Thanks for the input. I've only been charging or desulfating 12v car batteries. I did start on one Tuesday and do want to see the results after six days. But will disconnect before leaving for Japan.
Thanks again,
wantomake
How to I reconfigure my stator with this configuration?
My wiring configuration looks different than any I've been able to find in the forum. Does anyone know how I need to configure it? See pic
Thank you!!Attached Files
Superb Work!
Fantastic Job! Clear, concise and superior to any other mechanism (project) of similar type on the Internet.Originally posted by **~Imhotep~** View PostHi my name is Imhotep I will show you how to get free energy possibly for under 50 dollars from radio shack this unit will :
1 run inductive loads directly View video here
2 quick charge conditioned batteries. View Video Here
3 run resistive loads. Use Inverter and 12 volt batteries.
4 run capacitive loads !!caution!! SEE VIDEO FIRST PLEASE
5 charge unchargeable batteries : Ni-mh ,lead-acid, ni-cad, alkaline zinc carbon
6 you can build this unit in minutes
7 watch all videos, save them if you like. Share them if you like.
8 research all copyrighted materials and comply with all copyright laws
9 observe all warnings and precautions
10 build it now and possibly enjoy free energy
11 share your new knowledge
12 this is how done!! WATCH FINAL VIDEO HERE
A consideration
I find a lot of the misnamed 'Free Energy' is merely the recombination of mono-atomic Hydrogen (H1) back to diatomic Hydrogen (H2). Since it only takes a charge of 103 cal/gram-mole to separate H2 to H1 and when the H1 recombines under normal environmental conditions it liberates 109,000 cal/gram-mole. This explains to heat, molecular 'agitation', pressure and 'free energy' that appears in the lead-acid battery.Originally posted by **~Imhotep~** View Postive had some batteries that continued charging after they were removed. they would continue charging until they burst their seals. and as long as i wasnt drawing current off of them they would destroy themselves. ive also had a battery that is still giving off power and has not been charged since 2008. if u go all the way back in this thread you will find me mentioning in 2008 a clock that continues to run to this day with no signs of running out of energy. aaron had thought it had become an electret. so yes i have experienced some batteries that continue to produce energy. i dont know under what circumstances or what fan i used at the time so i dont know if i can reproduce those same results
This is explained in the book 'Occult Ether Physics' by William Lyne and is verified in the fifth edition of 'Van Nostrand's Scientific Encyclopedia' (1976). This particular explanation absolves the reasoning for exotic mathematical diatribe of 'quantum fluctuations', 'multi-dimensional energy penetrations and aggregation' and can be verified by well respected reference books which are freely available. You don't even have to tread the lesser known path of Bearden's 'Scalar Electromagnetism', Maxwell's 'Quaternion Algenbra', Heaviside and Stenmetz's slightly 'easier' math or the more esoteric theories of tesla and Eric Dollard.
As a former engineer who only got paid when you could actually physically manifest in this reality the fantasies of architects and design engineers the idea of a chemical hydrogen process gels much better with my sensibilities. I do have one request for your good self: Is there a larger fan that can be used instead of the normal 75mm computer fan as in your videos? I have currently ruined 5 such smaller fans since my soldering abilities are fairly basic and I don't possess the little hands and dextrous fingers of your missus. I AM the size of a Rugby fullback and my ham fisted attempts to replicate your device specifications is merely driving me to distraction. Any help here would be surely appreciated.
Anyway, keep up the excellent work and keep your head down when the G20 and the Aussie 'Police State' come to Brisbane next year.
