  • the fan i modified is a 4 3/4" fan i bought from the electronic store.this is the largest DC fan available in my area. its not like the PC-fans with windings on 4-poles. the winding is bifilar wounded clockwise in just a circular manner - i did not rewind it - i use the original windings its #27. since its bifilar i use one wire as trigger and the other as power coil (generic bedini circuit) - with this setup it works ok. but when i add another winding on top of the original two i won't work anymore so i stick to the original bifilar and remove my addition. this is why im asking if anyne knows how to wind a fan to use two transistors. i don't have a picture of the inside yet maybe i can disassemble it later or maybe i'll just buy a new one. the box houses the circuit and the two switches for the swapper. the picture with the battery is actually running but my camera can't see it moving.
    • shingot
      I do have computer fans that are wound like that also and they do work with my one transistor SSG circuit I have. But the five inch fan that comes with Rick's kit are larger versions of the four pole ones. Looks like stargate22 answered your question anyway.
      FRC
      • thanks stargate, i'll try them as soon as i get my wires, my original windings were broken already so i'll be needing new ones.
        • Originally posted by stargate22
          It can be done ...I've done 4 transistors...hexfiler wound and boy that rocked!
          You will have to unwind your current factory windings and go from scratch with a quad -filer wrap of "CW" / "CCW" 'til ya reach the end of the stator.
          Just hook your wires the same to trans...after all , now ya have 4 wires...right?
          @ stargate,
          by hexfillar you mean 6 strands right? but you only have 4 transistors - so 4-strands for power and 1-strand for trigger equals 5-strands. what's the use of the remaining 1?
          same with quad-fillar for 2 transistor setup, i suppose i will only need 3?
          • shingot
            Shingot, I am curious, are you using the r-charge fan kit 2 transistor circuit or
            another one like a darlington setup or something ? I am thinking of trying your
            one transistor version since I do have those kind of fans and I could never do
            those little four pole fans ( Imhotep version) right.
            FRC
            • Renewable energy i can't get to work
              I tried to get Imhotep's design for renewable energy, but can't get it to work, any help would be appreciated???
              • @ FRC
                im not using r-charger kits. it's just a fan i bought from store. yeah its easier to work on that bigger fan than those small four-poles computer fans. since all you have to do (on the bigger fan like mine) is separate the two windings then use one as trigger then the other one as power coil.
                im using the same schematic/circuit with the r-charger kits but only one transistor. its an ordinary bedini circuit - one transistor, one base resistor and one diode connecting emiter to base.
                @ stargate
                i can only understand the 2 wires ( 2 at start / cw.....2 at end / ccw ) = 4 wires = 1 trans. connection
                but not this 6 wires ( 6 at start / cw....6 at end / ccw ) = 12 wires = 3 trans. connections
                are you using individual trigger for each transistor?
                ex. 1 power - 1 trigger (for one transistor)
                so, 3 power - 3 trigger (for 3 transistor)? is this what you mean..?
                coz my understanding is for six-strands you can already have 5 power strands for 5 transistors triggered by 1 trigger strand. - one end of trigger wire goes to the base of each transistor (with base resistor of course) and the other end goes to the emitter of each transistor. - the ends of the 5 power stands are joined together for + supply, and the other individual ends of each power strands goes to the collector of each transistor.
                pls correct me if im wrong about this..
                • Originally posted by Thaddeus View Post
                  @Thaddeus
                  Your not alone. I did get fans to work but not Imhotep's way. If you could
                  explain more of what you did maybe someone here can help.
                  @shingot
                  I know what the r-charge circuit looks like for two transistors, but I don't
                  think it is legal to post it. I was wondering how you were doing two
                  transistors ? Or are you trying to use two single circuits together somehow?
                  I still want to try your single circuit setup. I already have a fan like yours
                  apart to do it with.
                  FRC
                  • @FRC
                    this is where i found the circuit.
                    http://www.energeticforum.com/renewa...lp-please.html ...
                    i only use the circuit but not the windings. - only one transistor used.
                    • shingot
                      Those are the kit circuits. I burnt out one coil the first time because I think the
                      circuit is wrong like is stated in that post. Second attempt fried the transistors because of short. Have not tried it again but will eventually.
                      FRC
                      • @FRC
                        is your stator the same as the picture on post #830 by skywatcher? mine looks like that.
                        • shingot
                          Originally posted by shingot View Post
                          @FRC
                          Yes it is. The fan kit is different. Just a bigger version of the small four coil Imhotep ones.
                          FRC
                          • shingot
                            @FRC
                            Shingot, I should have thought of this before, that two transistor circuit was
                            designed to be running on 24 volts. Have you tried that with your fan ?
                            FRC
                            • i haven't tried the 24volts supply yet, coz my fan has only 1 transistor, but according to the schematic it can be supplied from 8-36volt,
                              • Tesla and Bedini progress
                                Hi All,
                                I came across your forum and this post today and wanted to ask you if you have made any more progress on this Bedini free energy small generator since 2008. Also is this considered a zero point generator?
                                Thank you
                                Maryellen
