  • Hi folks, hi blackchisel97, not sure if you've noticed this as I have with J.B. solid state circuit. I'm charge/conditioning a 6 cell nicad 1700mah pack and drawing 400 milliamps input using 13.8vdc supply and when I try the 1 ohm test the input drops to 140 milliamps and volts across 1 ohm show .6 volts and i notice the frequency decrease when making the 1 ohm test and when charging the battery the frequency is at least double if not triple. Does anyone know if when put back on charge battery, is it still seeing the same overall output watts with maybe a reduced voltage due to lower impedance, so as to be in the safe region as per the 1 ohm test. This confuses me since I thought with the blocking flyback diode it was supposed to be independent from input, transistor off collapsing field. It's charging well though and bringing the battery back to life. Any thoughts appreciated.
    peace love light
    Tyson
    • what if we use UPS?
      Hi
      i really like this idea for this but i was think if we have ups we know the battery for the ups will down maybe after 15 min what will happen if we use it maybe will work or maybe now if its work really we will have FREE ENERGY source for long long time .
      correct me if iam wrong just think
      • Out of curiosity... does anyone know how the speed and input power compare to how the motor's ran originally?
        • Interesting thread. Anyone try this using hard drive motors. I notice they have 4 leads that seem to be going to a pulsed logic circuit, like a stepper motor is what i was thinking. I could be wrong with that assumption. Ive tried powering them up by themselves without any luck. Seems they need a stepped input pulse to each terminal
          • Comment
            • Originally posted by sumitbm View Post
              2. Now I put the load in the circuit, in the form of charge battery (as specified after diode) and I could see the neon bulb is getting off, voltage (120v drops to lot less ~ 12 - 17v) and the current from o/p is ONLY ~ 1mA to 5 mA. Which is very very less current I believe. Now the question is, whether this is expected?
              Yes. That is expected behaviour. Output will have outptu voltage inverse with load resistance. Load with high resistance will be charged at higher voltage. Think this circuit as charger with constant power output.
              3. I started doing some modification related to operating frequency of the circuit and found a bit good result in current drawn to load and the load current max I could get from this circuit is ~50 mA. Which still I believe very less to charge a battery, I mean charge battery will take long hours to get charged. :-(
              You can increase output, but not with this version. You need to use bigger coil to get bigger output.
              However, you should notice a significant charging speed compared to normal charger. My variant charge about 4 times faster than common charger at the same input power, more if counted from output current.
              One more point, if I just connect the charge battery (load) to the input battery directly then the current drawn is much more (~ 100mA), so I think the source battery is supplying all the needs and as per physics principle there is no free energy at all.
              On most variant, input current will increase when you add load. Tuning the resistor value is needed to obtain the best output per input ratio.
              And this device is never intended to provide you with free energy. To get real free energy device you may have to invest money as much as your lifetime electricity bill. However, this device is a very very good charger. If you need a charger, this device is better that anything else, especially if you consider the price to build it.
              • Thanks Sucahyo for detailed response!!
                I have little doubt on whether I am getting any free energy at all, could you share the variant charger circuit so that I can have a look? I am really not much convinced how the charger can do fast charge w/o much o/p current.
                Please put your valued comments / suggestion.
                Thanks once more.
                -Sumit.
                • Can be used Bedini window motor circuit do?
                  Hello everyone:
                  Bedini window motor if we adopt the half-bridge or full-bridge circuit can be a normal job? It will be more efficient?
                  Xu Yuan
                  • Originally posted by yx630514 View Post
                    Hello everyone:
                    Xu Yuan
                    From what I remember, many people sugest that window motor energy is not supposed to be use for other purposes other than self running.
                    • I just built one of these fan chargers and i am really impressed. I rewound the coils myself using #34 as trigger and #30 or #28 not sure, for power. Coil is one long bifilar strand wound across the 4 poles in series, 50 winds per pole. First pole cw, second, ccw, third cw, fourth ccw. It draws about 450ma at 13v and rpm is very high. If i seal the front and back of the fan, the rpm more than doubles without any additional input. Voltage across 12v 4.5ah battery while charging reaches 16v and settles to around 13v when disconnected.
                      6.6 ohm trigger
                      2 ohm power
                      4 ohm 12v bulb trigger resistance to base
                      • Anyone tried snapping the blades off of the fan? I just did it and the rpm must be well over 5000
                        • Originally posted by 1NRG24Seven View Post
                          This may be useful :
                          Using disk drive motors
                          Experience is a hard teacher. She gives the test first and the lesson afterward.
                          • deepcut, this is the answer to your pm
                            you replace the circuit with your own bedini circuit(how to build the circuit is covered in the video) and only use the frame and coils so you do not have to fabricate your own stator and rotor assembly. good luck hope that helps
                            Nikola Tesla
                            http://www.imhotepslab.com
                            • Welcome back
                              Long time no see Imhotep!
                              See my experiments here...
                              • new circuits and expansions coming soon
                                my videos have spread like a tornado all over the net.
                                i am shocked. and pleased .i just got time to pop back in and was pleased to see some new circuits.
                                i am hopeful that i can complete some more circuit modifications and release them and some completely different circuits, as i continue to see off the shelf circuits that can be modified.i must choose carefully what is released.
                                hope to be back soon
                                imhotep and shiva
                                Nikola Tesla
