  • ahausurf
    I have a video you may like
    YouTube - Maybe negative resistor
    Take Care
    B
    • Welcome
      welcome aboard ahausmurf!
      It's a long wait to become a member. For others waiting, there's a thread somewhere with an email to send your intended username to, which speeds up membership :-)
      • negative resistor
        Originally posted by Bodkins View Post
        ahausurf
        Take Care
        B
        From Wikipedia:
        "Constant "positive" resistor + "over-acting" varying voltage source = absolute negative resistor"
        Negative resistance - Wikipedia, the free encyclopedia
        Peace
        PJ
        A Phenomenon is anything which can be apprehended by the senses.
        • Comment
          • Hi John,
            I have successfully ran an old 5.25 floppy disk converted to a bedini fan motor setup. the one I have has 30 coils. I discontinued the test as it was drawing about twice the current of the 4 pole fan motor rig. I was not too careful tracing the coils so I likely had a few wired badly however it stll ran respectably.
            When you pick up a cat by the tail you learn things you cannot learn any other way...
            • Ebm=ou
              Hi Bodkins;
              Here's a video that's also exciting!(it's in the gallery section)
              Gamma Manager
              Al
              Antiquer
              • Originally posted by ANTIQUER View Post
                Hi Bodkins;
                Gamma Manager
                Al
                Hi,
                The last wht i did hear from the EBM was, that they discarded it,
                and claim, it dont makes OU.
                That was developed by a Hungarian Comapny, what did do a 19 Years research.
                Whatever is true..
                • Coils
                  Hi guys,
                  I think my coils are mixed up some how.
                  I got the post in and soldered one of the wires to and then the remaining wire back on to its original post.
                  Trying to establish which two are positive and which negative I attached the battery to one I marked positive and one I marked negative, nothing happened, however, if I join the other two wires then I get the fan moving into a locked position showing power.
                  The same happens if I join any two wires together and put the remaining on the battery.
                  Does this sound right?
                  My SSG circuit seems sounds I have gone over and over Imhoteps video and it looks perfect. But when I hook it up to my fan I get that locking of the fan showing power but it will not engage if I spin it.
                  I really really appreciate the help.
                  • Originally posted by splay View Post
                    Hi guys,
                    Sounds like your transistor is bad or you have a diode backwards. disconnect you fan all together from your circuit and check the coils with a continuity tester. Keep one lead on the same post and check all of the others. Only the other end of the coil should reveal continuity. also if you disconnect your transistor there should be infinite ohms from the collector to the emitter.
                    Matt
                    • Hi,
                      Measure, wich both Wires have have outlet,
                      then try to other too, if they have outlet too.
                      When both are ok, you found your 2 Coils.
                      Now connect one Wire from this Pair from one Coil to Plus at Batterie.
                      The other Side of this Wire to the Collector.
                      Now you got one Coil done,
                      Now connect one Wire from the second Pair, wich left now, to Minus from Batterie.
                      The last Wire connect to the Potentiometer/Resistance, what goes at the Base from your Transistor.
                      Spin it up, when it dont works, switch Either the Wire at C and Plus,
                      or switch the Wires between Minus and Base/potentiometer.
                      When it locks at a Position, means, you only need to switch one Pair of a Coil.
                      Just make sure, that you have the Wires right connected to the Transistor.
                      When the Pins are at the lower Side of the Transistor, when you look at it, then should be the right Pin Base, left Pin Emitter, Case is Collector.
                      • Originally posted by Joit View Post
                        Joit Hi,
                        Thanks for your help.
                        You say, connect one negative from the fan to the collector?
                        I havent seen that on Imhotep's video.
                        I see him connect one negative to the Emitter and the other negative to the source battery.
                        Am I wrong there?
                        • splay,
                          Imhotep's video indicates that he labels the inside wires as the negative - and the outside wires as positive +. I think. Check for yourself, it's in his first video at his personal web page. Also the FAQ there is quite helpful.
                          Imhotep's Laboratory | Renewable Energy
                          Peace
                          PJ
                          • Sorry Im a bit confused.
                            One of the fan negatives attaches to the emitter from what I understand. You say it attaches to the Collector?
                            • According to Imhotep's diagram: The negative - on the black goes to collector on transistor AND anode on diode. The Negative - on red goes to variable resistor.
                              Peace
                              PJ
                              • Originally posted by ahausurf View Post
                                ok this are the pictures from my one, i put it on a litle box, and cut the wings off the fan, so i have get i volt up.
                                hehehe whats that mean negative resistor,
                                uff i get lost, litle by litle, thanks any ways, i have check it out, i did not realy undestund so much
                                any ways, mine it is giving to me about 4.30 volts, you guys say that you can use many fanes to get up on power, i have saw other guys on you toe how take about 130 volts on inline whells and home made coils.
                                my question is . how we can o how many volts we need to power our house, which way, it will be bether, i have no idea about electronics but i so interesting on learn all about for this good cause.
                                sorry for my englis and greting from spain
                                start reading this loads of info
                                All@everone read this it will help setting the fan up too!!!!
                                also dont forget the earth battery stuff gentlmen this will help the charging noend
