Hello,
A simple device that the inventor claims that has a COP of around 20.
It simply consists of two bell shaped bowls within each other not touching. Alternating current of 50Hz or any other frequency is applied across the two bowls, while the bowls are in water. The water heats up so fast and quickly reaches to boiling point.
The trick as it is claimed to tune the bowl so that 50Hz or any other frequency applied is the resonant frequency of the system. The tuning is done by adjusting the distance of the two bell shaped metallic bowls from each other.
This is quite interesting if it works as claimed. The full document is attached.
I wonder what will happen if we pulse the bowls? Will it heat the water too or make Hydrogen?
Maybe I'll experiment with it later to see what's its capabilities.
Good Luck
Elias
Good Luck
Elias
But I don't know if it has COP > 1. It boiled two liters of water pretty fast. I am looking for a way to tune it to get the most out of it.
