one last thing,
if you have not powered up a new amplifier before,
make sure to set your gate bias to zero volts before powering up the circuit for the first time.
then watch your power supply current as you up the voltage on the gate to the required idle current.
this is because on the max bias setting you potentially damage your amplifier with over current.
A fuse on your power in can also make sure that error does not break things.
