thanks for the comment
Multifilar Generator Coil - Lenz delay Experiments
Hi all, Hi bromikey, ok here, just taking a break from it and maybe the rest will bring inspiration.
Thing is also, the results were not very good with my setup, not much useable power.
The smaller 4" rotor seemed more promising, the speed up was very obvious and audible, though again, not much useable power with that version also.
I'm probably doing something wrong, just not sure what that is, so I wait for inspiration.
Working on a flywheel generator project I never followed through with at the moment, similar to chas campbell device.
peace love light
"BroMikey " You asked me about my "C" core?
If so, and how good you are moving forward, and then show your project already finished.
SkyWatcher, you keep moving forward in the flywheel system, none of the projects is simple, material and economic inputs are required, and time to be assessing each change or improvement.
and if it is true in occasions, a break is taken to recover some strength and inspiration
but happy day companionsLast edited by alexelectric; 09-02-2019, 08:43 PM.
Hello Sky and AlexOriginally posted by SkyWatcher View PostHi all, Hi bromikey, ok here, just taking a break .........
I am changing things right now but I have to hurry because I am teaching
this in school this year to my son Jordan. I had to make out riggers to
accommodate the large diameter coils that are narrow not wide.
It is also important to make a cover for safety during operation. Jordan
and I are working together on his project during school hours. Still got
to cover readin, writin and rithmatick
Look at current handling at 1000ft. for 29awg it is 100ma. So let's sayOriginally posted by SkyWatcher View Post
the average small rig needs 200watts to run the dc drive motor that
turns the rotor and magnets. Using 100ma say at 100volts= 10watts
BUT each coil should have 3 channels of around 1000ft so 3X10watts=
30watts per coil at best case. This would require you have coils to
reach the break even point.
Chart showing current handling AWG wire for 1000ft and over.
Using 25awg I am targeting 333ma per strand X channels=1000ma
per coil so only 2 coil packs are needed to reach the break even point.
Look at the chart for awg power transmission current capacity. It
shows a max rating of .729 amps or 729ma. This is the size wire
Dave has used for years yet he only takes 500ma per strand X 3=
1500ma per coil X 130vols = 195watts of light bulb blowing genius.
Do the math
Totals
x 12 coils is 2340 watts.
I have always said between 1,800-2,000 watts output, but that is dependent on the rpm. Higher rpm gives more output.
And the numbers I quoted for my machine were for:
A rotor turning at 2800 rpm
With six 2" by 1/4" magnets on the rotor
12 coils
With six 1" by 1/4 inch magnets I got 75 % of that output
With twelve 1" by 1/4 magnets I got 150%
With twelve 1" by 1/2" magnets, which is what I have NOW, I never got final numbers. But I would bet the output is pretty good. And you can run it on higher RPM if you want more output.
To cool, that is alot of data compressed over time. I am so glad to have it.Originally posted by Turion View Postx 12 coils is 2340 watts.
12 coils
Hope your day went well.
Yes of course Mr. Turion, the 2800 rpm are what you have been proposing and as a basis I take them.
Of course one can change the conditions and there are changes.
* more magnets more magnetic flux to induce
* more revolutions more magnetic flux to induce
* increases coils there is an increase in generation
What I take into account, Mr. Turion, if the induction and the approach and the lowering of the lenz, is given by the form of the series-parallel multi-wire coil, since in the generation of energy, if it leaves the rpm that is generating the objective is no longer met, if at 2800 rpm it is generating and the speed rises, so that it will re-enter resonance it will be at an already higher speed.
and thank you Mr. Turion, for giving already proven data of your experiences, this serves to guide us in the projects.
With a coil that I try to replicate Mr. Turion and give me the expected results, it would help me to assess where I would go, because I want generation at a lower speed, but I would have to increase the magnets, the threads of the coils, but it is advanced and learned.
Thank youLast edited by alexelectric; 09-03-2019, 04:54 AM.
Answer
alexelectric,
You already understand the answer. 2800 RPM was for six magnets on the rotor. I already KNOW that with 12 magnets on the rotor it would speed up under load at a LOWER RPM. I just don't know HOW low because I never reduced the input to the motor with any kind of motor controller. I DO remember seeing speed up under load at around 1800 RPM one time, but I don't remember the coil configuration at that time. I tested a LOT of coils of different sizes and different sized wire.
So adding more magnets allows the effect at a lower speed. So will more wire. LONGER wires would change capacitance, but not as economically as more strands in parallel and connected in series. Despite the fact that UNINFORMED people (bistander) believe that more than two wires makes NO difference, others here have PROVEN that they can't even GET the speed up under load effect without several wires in parallel connected in series. You would be better served by not listening to ANYONE who has not demonstrated that they have actually BUILT one of these coils and DONE the experiments.
I have NO idea how low you can go with RPM. You have to remember that lower RPM will dramatically lower your output, but the MASS of your magnets and the number of magnets and the mass of your coil wire will push that number back up. Sooooooo much research to be done.
Multifilar
Hi Turion,Originally posted by Turion View Postalexelectric,
How long before you delete these posts?
Misquoting me again. I never said "NO difference". Rarely can you make changes which result in no difference. Without finding our previous (half) discussion, I believe what I said was more than two reduces substantially, and can essentially eliminate the effect Tesla sought with his bifilar coil. Ever wonder why Tesla never mentioned trifilar, quadfilar, or multifilar? Or bother claiming such in his patent?
But it is a moot point because none of this affects, in a positive significant manner, generator performance at the voltage and frequencies involved.
procedure
Anyone who wants to understand what is going on with these kinds of coils.
1.Wind a coil with a single strand of ANY size wire and keep adding length until it speeds up under load. I would recommend adding a 100 feet at a time. Make sure you measure it as you do it. When the coil is big enough it WILL speed up under load, no matter the rpm or the number of magnets on the rotor. But you might have to wind a heck of a BIG coil to see it happen. I would recommend adding a 100 feet at a time. When it finally speeds up, start cutting off 10 foot lengths until it no longer speeds up under load. When it stops speeding up under load, add 2 foot lengths until it starts speeding up again. Now you are within a couple feet "perfect"
2.Then unwind the coil, cut the wire in half, and rewind with only two strands in parallel and connect them in series. Now start cutting pieces off in 2 foot lengths until the coil no longer speeds up under load. (Each cut will remove 4 feet of wire...two feet on each strand. This will prove to you that two wires in parallel and connected in series have more capacitance, and what Tesla says is true. Otherwise as soon as you cut off a couple feet it would longer speed up under load.
3.Now unwind the coil, cut the two strands in half, and rewind the coil with four strands in parallel and connect them in series. If the coil speeds up under load NOW, then whatI have said is true, because you already shortened it so it would NOT speed up under load in step two when you cut some off the two strands.
Or if you are LAZY, skip step #1, and just wind a coil with two strands until it speeds up under load, and then follow the directions in step two.
bi,
Aaron was a bit upset with me that I deleted my posts, so I believe he going to put them all back. So I won't be deleting anymore.
Yeah I was mad too, years and years of blood sweat and tears gone upOriginally posted by Turion View Post
in smoke in 1 minute. We need time to digest the info as a collective.
Keep it all right there don't listen to the other voices that say your
work is meaningless. You are the greatest for many reasons.
1 Bench work not all mouth
2 Well educated
3 Good public relations skills
4 Persistent knowing that others need time to hear the repeats.
The list is so long. That is why you have made it nearly 10 years
Oh you have your moments like any man, we all get over. Think of
it like this. Whatever you are like today is what you will be like
tomorrow and based on this observation a persons trajectory can
be determined. It's still prime time.
Our generators are anywhere from 1000 percent --- 3000 percentOriginally posted by Quantum_well View Post
efficient. Now there is your sky limit. .98 output? Lame.
