to find out what this thread is all about,
download this PDF http://blog.lege.net/Mathias_Bage/GL...-annotated.pdfother things I tested in the past.
So, at least to me, it really looks to me like this idea is worth replicating
I first went at the design from the point of view as if it is a particle accelerator.
that seems to be the point of view of the person that leaked the idea of the device on the web.
but now I am wondering if the leaker had got the idea a bit wrong from whoever he got it from, or even potentially the techs working on it just used poor word choice to tell what was going on.
if it is a an open air particle accelerator, then the more you optimize the design, you end up with 2 coils that are single turn and set inside each other at 90 degrees, the frequency will be the one wavelength resonance for the single turn. They will be electrically driven at 90 degrees out of phase. And will be inside a DC magnetic field at the other 90 degrees from the other 2 coils.
so that is what I built.
I had enough of a DC magnetic field (about 800W in if it matters), but only had about 35W in for the spinning field. I ran it in the 1.25 meter radio band.
and it just did nothing.
from the leaked info, they said that around 40 megajoules was a very marginal field.
so I guess my power in was way to small. but having seen some of the effects in the 150W or less range with physically spinning magnets, so now I am left wondering if the particle accelerator idea lead me down the wrong path.
now I am wondering if it is accelerating something like ether (or a time field)
many models of reality don't help us here, but
if you look at the science of wilbert smith, he says this reality we are in is made of "frozen reality", and tells you where it is frozen at. And if he is correct, the MAGVID is the sort of thing that you would build to melt this reality.
melting reality would make that volume fluid like a dream world.
and if this is the case, then it is all about power into the field.
then you don't need frequencies that would be suited only to electron acceleration, and this makes it quite a bit easier to build (without having it kill you when you run it).
so I tried building that, had about 50W in to the field in about the 40KHz range into what was about an 15 inch sphere, and got nothing form that as well.
have thought this through, and I need more power if I want it to work.
Strikes me as the easiest way to get more power is to make the coils resonant. A simple coil capacitor resonance is pretty efficient at bringing up the amperage in the coil, kind of a pain to tune though.
and would need to do this in 2 to 4 coils all at the exact same frequency. Pricey, and annoying, but possible
I am considering using 10.7MHz as that is where some plasma welders run, so the RF noise from it should be unnoticed and should be possible to get a high power source somewhat easy as harbor freight tools sells the cutters that use that part, but still unlikely to get to the quoted 40 megajoules lower limit.
anyone else have any thoughts on the MAGVID ?
not trying to distract from any building on likely more tangible ideas,
I am just trying to set up things to keep in mind when testing current projects, and what might happen if you face the magnets at 90 degrees to what people are building for the Alexey Chekurkov verification. and maybe when that project is done, this MAGVID idea could be explored to more closely get all the features that are seen in UFOs in the sky
