Diy magnetic field scope/a scanline e-beam plane imaging tool.
  • #31
    Still do not see a SPIN??!!
    Let me know whenever you do...
    Now, honestly Bistander,
    If you still don't see a spin on previous images...then let's take this topic over to the Open Thread and allow others to tell me it is not a spin.
    Or maybe Citfta can explain your suggested "Orthogonal Lorentz Forces" with all required Graphics and calculations (since you could not do it) to this specific magnetic rotations...
    • #32
      I see displacement. Remember that the force is on the beam, not the scanline.
      Got to go. See ya
      That WAS NOT THE ONE I WAS REFERRING TO, OF COURSE ABOVE IS A DISPLACEMENT SINCE IT IS GOT NO CENTER POINT OF ROTATION!!.
      I AM STRICTLY REFERRING TO THE SPINS FROM FRONTAL NORTH-SOUTH TO CRT HORIZONTAL SCANLINE.
      Please do not play "retarded" here.
      The MAGNETIC FORCE acts on the SCANLINE PLANE, NOT JUST TO THE BEAM ITSELF, BUT TO ADVANCED RASTERED PROJECTIONS OF THE BEAM...OR VERY HIGH SPEED "BEAM SAMPLINGS", WHATEVER WAY YOU WANNA PUT IT.
      If the Beam would NOT be moving that fast, then we will NOT see SUCH SMOOTH SINES HERE, BUT VERY SHARP/STEEP UP AND DOWNS...LIKE NOISE SIGNALS, MAYBE FOLLOWING SAME SHAPE.
      But that is NOT the case.
      Besides the fact OF A SMOOTH SIGNAL CONFIRMS that Magnetic Forces are applied to DIFFERENT SPATIAL POINTS (MULTIPLE) OF THE RASTERED SCANLINE PLANE.
      Ever build planes and deflect them based on spatial points-which defines spatial curves- with the help of integers to calculate their true shapes?
      Here the same thing applies.
      Definitively I will have to send you to check if you have ADHD
      • #33
        Originally posted by seaad View Post
        And now it's XXX turn to make a kick off.
        But no OU in sight.
        Have fun
        Regards / Arne
        If you do NOT understand what is BEING explained here...then HOW COULD YOU EVER UNDERSTAND OU?
        So, shut up, and read first!
        • #34
          Help Help I'm poisoned . . . . Oooh . I'm so dizzy it's only spins
          "If you do NOT understand what is BEING explained here...then HOW COULD YOU EVER UNDERSTAND OU?"
          Because YOU are understanding what you yourself are writing. Then, Why don't we see any OU-unit from you?
          The caveman didn't understood how the chemicals in the fire was working either but he got fire.
          • #35
            What?
            Yeah, sure...SO MANY BEAUTIFUL "PROTOTYPES" ...that would never make it to the Market...same ol story...for another 200 years more.
            What? These equipments (vehicles) are currently and have been powered by electric motors. Here's one of the largest surface vehicles which was powered by eighteen 1000 hp electric motors. The 13,800 volt feed line could have been to a non-carbon source. https://en.m.wikipedia.org/wiki/Big_Muskie
            Yep, got off topic. I'm fine taking discussion over to citfta's thread.
            • #36
              That was VERY FUNNY Bistander!!
              Big Muskie was powered by electricity supplied at 13,800 volts via a trailing cable, which had its own transporter/coiling units to move it. The electricity powered the main drives, eighteen 1,000 horsepower (750 kW) and ten 625 horsepower (466 kW) DC electric motors. Some systems in Big Muskie were electro-hydraulic, but the main drives were all electric.[3] While working, Big Muskie used the equivalent of the power for 27,500 homes, costing tens of thousands of dollars an hour just in power costs and necessitating special agreements with local Ohio power companies to accommodate the extra load.
              So it weights around 27,000,000 Pounds or 12,000 Tons (very "lightweight!!)
              And the 13,800 Volts are taken to the "monster Frankie", sorry Muskie...VIA A TRAILING CABLE!!
              I imagine building up that much power with batteries (yeah, deep cycle) we would need an entire city right?..so vehicle won't be able to carry that many batteries...it won't even move...
              WOW!, VERY IMPRESSIVE AMUSEMENT MACHINE...
              It reminded me of the old Kid Toys when there were no R/C yet...and they needed a cable from the control to the small car...
              PERFECT EXAMPLE OF HOW ADVANCED WE ARE IN ELECTROMAGNETISM AND ELECTRICAL POWER!!
              When did you say it would go on production?
              • #37
                That's a perfect example...look how many cavemen burnt out his caves with their families inside by playing with fire without the proper knowledge...
                And even further on, in other times...some people were under the belief that the flames from the fire would release their demons and rise them to the skies, "purifying" their poor souls by the fire...
                And now you want me to give it to you without even knowing about it?
                Got to be kidding right?
                Go find some sweet stuff to eat, Ant...
                • #38
                  Even if the caveman burnt out his family he still could produce fire without knowing the principle it works on. Not the principle of how to prevent proliferation. (OU-growth uncontrollably)
                  But I have given you and all all my best test results showing OU indications. With good intentions. True technical OU or not? It is the audience task to solve the inaccuracies I can't see. But not any from the audience seems to be interested. But in your case and mine, it has something to do with phase angles.
                  Regards / Arne
                  • #39
                    Regards / Arne
                    Seaad,
                    I am sorry but your attempts were not "ready to use" applications...and that's what normal people wants, reason why you did not get any attention.
                    Whenever you prepare a "Plug and Play" OU Device, where it is proven to power loads above their consumption (Input)...only then you will have the whole WORLD ATTENTION...but just be careful, as also all the paid shills will come over to screw you up.
                    What I am doing here is showing how to use a very useful tool that will help you to visualize your Field behavior, magnitude plus all different pulses required.
                    But like in any teaching of "how to" we have to start from the first things first...just like 1st grade, 2nd, 3rd...etc,etc...until you become an "advanced user".
                    comprende?
                    Good!!
                    Now goodbye
                    • #40
                      A Russian Experiment demonstrating the Same Magnetic Spins...
                      Hello to All,
                      This morning I had one new comment on my CRT 1 You Tube Video...with a link to an Experiment done in Russia...
                      [VIDEO]https://www.youtube.com/watch?v=s0g1bHp6-uA[/VIDEO]
                      Titled: Магнитное поле и Эл ток (Magnetic Field and Electric Current)
                      He is running a Current (Amperage) on the thin wire...and it "automatically" wraps, winds itself (...or could we also say "magically"?) around magnet... exactly in the spinning direction specified here and revealed by CRT Tool shown...Interesting test, I believe.
