2018 Energy Conference
  • #16
    History, Theory & Practice of the Electrical Utility System by Eric Dollard
    "The Grid Is Being Degraded And It Has Become An Antenna To Amplify The Damage Done By An EMP! This Is One Of The Most Disruptive Presentations Ever Delivered By Eric Dollard. Correcting These Dangerous Practices Is A Matter Of National Security."
    REVEALED: How the power companies are bypassing safety features and other built in securities at a higher cost evidencing the fact that competent power engineers appear to no longer exist - they're sabotaging the grid and don't even know it. This presentation is 5 hours long!
    • #17
      Fourth Phase of Water by Dr. Gerald Pollack
      "Water Is Thought To Be Simple, Yet It Is One Of The Most Misunderstood Substances Known. Learn The Latest Breakthroughs In Water Science Including A Peak At SOLID Water At Room Temperature And Other Paradigm-Shattering Discoveries!"
      REVEALED: Dr. Gerald Pollack discoverer of the Fourth Phase of Water shares the Latest Breakthroughs in Water Research!
      Look at a few of the profound revelations you will learn in this presentation:
      • How there is a 4th phase that is different from solid, liquid or vapor.
      • How water can be separated into two types in one container that can be used as a battery - has already been proven to be able to light an LED - there is no electrolyte in the water or dissimilar metals, it is 100% water in two different forms.
      • A glimpse at SOLID water at ROOM TEMPERATURE - that's right, easy to come to an understanding that almost anything anyone thinks they know about water is probably wrong.
      • How water can desalinate itself as well as separating out other particles.
      • A discovery showing how water actually flows through capillaries and assists the blood pumping action since the heart is not capable of pumping all of the blood as is commonly thought.
      • Free water pumping action through a tube at an infinite COP (coefficient of performance) since we provide zero input and any other input comes from external sources.
      • And much more...
      Get your copy now: Fourth Phase of Water by Dr. Gerald Pollack
      This code gives you 25% off for a limited time: WATER25
      • #18
        Gravity Control with Present Technology by David Alzofon
        Get your copy here: Gravity Control with Present Technology by David Alzofon
        Get 25% off with this coupon code for a limited time: GRAVITY25
        The chart below was computer-generated during the 1994 experiment. The vertical axis tracks weight and the horizontal axis tracks time. The weight began to plummet the moment the system was switched on.
        So, abandoning any thought of personal gain, he decided to do all he could to publicize the technology. He opened the books on the 1994 experiment in hopes of encouraging replications of the experiment with improved digital equipment by responsible scientists and entrepreneurs, thereby ensuring its dissemination into the mainstream of science and engineering. Already, there are signs that his strategy is working. And, as he amply demonstrates in the book, if the technology works, the moneymaking opportunities are astronomical. Dr. Alzofon assessed the value of his invention as equal to the combine GDP of all the industrial nations on earth within ten years of its debut. Control of climate change is just a side benefit.
        Since the dawn of history, gravity and inertia have been regarded as more inevitable than death or taxes. The discovery of gravity control is on a par with the discovery of fire or the wheel. It is not only vitally important for the advancement of science, but for the evolution of mankind, as it opens the door to the final frontier: space.
        • #19
          Uncovering the Missing Secrets of Magnetism by Ken Wheeler
          Uncovering the Missing Secrets of Magnetism by Ken Wheeler Uncovering the Missing Secrets of Magnetism by Ken Wheeler Uncovering the Missing Secrets of Magnetism.
          Ken covers a massive amount of information that he compressed into 90 minutes, which obviously he could have gone on for hours.
          He covers:
          • He covers the nature of magnetism, which you will never find in a text book because largely, the academic world has no idea what magnetism is and they even admit it.
          • He goes into the various geometries related to the various aspects of magnetism.
          • The difference between small and large magnetic fields and why many people are disappointed when they learn the difference.
          • The results from many of his own experiments using magnets on seeds, etc.
          • Some vocabulary that on the surface appears to be simply jargon, but you will learn that certain words are used very specifically to make important distinctions.
          • How to build the advanced Ferro fluid cells, which are invented by his associates. This is perhaps the first ever open disclosure on this method.
          • How he used some of these methods for a very specific type of blood analysis.
          Get a 25% discount with this coupon code for a limited time: MAGNET25
          • #20
            The Meaning of Unity in Energy Conversion Systems by Jim Murray
            The Meaning of Unity in Energy Conversion Systems by Jim Murray Initially, it had been assumed that a simple ratio computed by dividing the output power by the input power would provide a reliable yardstick for motor power efficiency. The basic idea, was sound, for the closer the quotient came to unity, the nearer the motor efficiency would be to 100%. Hence began the so-called “Quest for Unity.”
            However, early “electric engines” were very inefficient, probably delivering no more than 30% of the electrical input power to the output shaft. Therefore, it quickly became evident that not all of the applied power was being converted to a mechanical output. Clearly, inefficiencies were involved, and they would have to be accounted for. Until this was complete, the simplified approach to establishing a Factor of Unity could not be realized.
            What is remarkable, in the history of motor development, is the curious degree of synergy that seems to have accompanied these early pioneering efforts. Between 1839 and 1850 the British Brew Master James Joule conducted an elegant series of experiments, in which he sought to unify electrical, chemical and thermal phenomena by demonstrating their inter-convertibility and their quantitative equivalence. The results of Joule’s work were published in the Philosophical Transactions of the Royal Society, with a very impressive title: “On the Mechanical Equivalence of Heat.”
            The contributions of Lord Kelvin must be considered next. His paper, “The Dynamical Equivalent of Heat,” published in 1851, contended that energy could be “lost to man irrecoverably; but not lost to the material world”. Thomson was thus the first person to understand that all energy changes involve energy dissipation, and losses.
            During the second half of the nineteenth century Kelvin and other scientists, including Clausius, Rankine, Maxwell and, Boltzmann, continued to develop these ideas. Their combined efforts resulted in the establishment of the Science of Thermodynamics; with Conservation of Energy as its First Law and the Dissipation of Energy as its Second Law.
            Accordingly, motor researchers were thus made aware of the extreme importance of classifying all known motor losses, and accounting for them with the same degree of accuracy as would be exhibited in the well established science of corporate book-keeping.
            Ultimately, such practices would lead to the development of two principle kinds of Efficiency Measurements, both very valuable in all research pertaining to rotating components, but, particularly valuable for developing an understanding of over-unity as a scientific fact. Both efficiency concepts shall be fully explained in this presentation.
            To get your copy now, go here: The Meaning of Unity in Energy Conversion Systems
            Use this coupon to receive 25% off for a limited time: UNITY25
            • #21
              2018 ESTC Panel Discussion #1
              2018 ESTC Panel Discussion #1 with Anupam Tewari, Jeane Manning, Dr. Gerald Pollack, Aaron Murakami, Prof. Robert Haralick, Karen Elkins, Paul Babcock.
              [VIDEO]http://www.youtube.com/watch?v=tn22g-RtMMs[/VIDEO]
              For videos from this conference, they will be posted at home - A & P Electronic Media
              • #22
                2018 ESTC Panel Discussion #2
                2018 ESTC Panel Discussion #2 with Dr. Charles Bagley, Yaro Stanchak, John Petersen, Aaron Murakami, Eric Dollard, David Alzofon, Ken Wheeler.
                [VIDEO]http://www.youtube.com/watch?v=XnmL6CwIAv4[/VIDEO]
                • #23
                  Hidden Dance - Zero Force Motor Part 2 by Yaro Stanchak
                  At the 2018 Energy Science & Technology Conference, more revelations are disclosed about the last one year of experiments with the Zero Force Motor.
                  Within this follow up presentation, you will find all the specs, which should be considered a standard built for more experiments to get start with. It works and has already been proven out by Yaro Stanchak and James McDonald.
                  Yaro also shares the differences in more detail on attractive vs repulsive mode and how this looks diagramatically so the viewer can benefit from these findings. A thorough walkthrough on the Zero Force Motor's timing characteristics of the magnet's geometry in relation to the coil geometry is covered. This is very important and cannot be stated enough - timing is cruicial and can make or break your results.
                  Keep in mind this is a developmental process and there are no free energy claims. It is a novel motor with unique aspects that have not been used or exploited in conventional motors and bit by bit, the potential of what this machine is capable of is slowly revealing itself.
                  Pay close attention to the date in the table presented by Yaro. You may find there is more than meets the eye. And you will definitely see that at certain RPMs, which may idicate some resonant points that you will see the Hidden Dance happening within the macine as Yaro shows on the scope.
                  There is also a difference in the characteristics of how the motor operates in relation to its waveforms that are measurable if the ZFM is running on a battery compared to a linear current power supply. In other words, there appears to be advantages to running it on a battery compared to a power supply. Professor Robert Haralick during questions points out a very plausible reason for this and that is that when running, the ZFM is producing longitudinal waves that are accepted by the battery(s) but the linear amp power supply cannot.
                  This would be completely consistent with John Bedini's experience over the years with experiments on the Bedini SG when running on and charging batteries, which have shown unusual input vs output ratios and most of this disappears when running these machines on conventional power supplies. It has been stated over the years that the battery is very important as part of the open system and once again, these ZFM experiments shown by Yaro seem to indicate the same results.
                  Here are a few of the subjects that Yaro will show in this presentation:
                  • Introduction and Brief Review Of Zero Force Motor Design and Operation
                  • ZFM Timing and Firing Duration with Coil Voltages
                  • ZFM Operational Characteristics; RPM, Amps & Efficiency
                  • Review of O-Scope Wave Forms for Voltage and Amperage
                  • Hidden Dance
                  Enough! Time to get back to the next round of ZFM experiments...
                  Zero Force Motor by Yaro Stanchak
                  Get 25% off with this coupon for a limited time: ZFM25
                  • #24
                    Electro-Biohacking, Influencing Gene Expression w/ HV by Aaron Murakami
                    Throughout almost three-hundred years of experiments, field trials, stringent academic research, etc. it has become indisputable that simply using electrostatic potential can drastically alter how plants grow.
                    Get your hands on this powerful information now: Electro-Biohacking by Aaron Murakami
                    Get 25% off for a limited time with this coupon code: BIO25
                    That was the inspiration to move into other experiments where germinating seeds and fertilized fish eggs were treated and something very unexpected happened. Growth not only increased, but the gene expression changed!
                    When corn seeds were treated, they went on to grow corn that had 5-12 ears of corn per plant!
                    When fern spores were treated, they grew into a fern that had been extinct for over 1 MILLION YEARS! Top image is the normal fern you seen today. The one below that is what grew after the treatment and fossil evidence shows that the non-micro serrated fern leaves have not been in existence for over 1 Million years!
                    The video excerpt below does not go into this amazing and unusual but highly beneficial effect, but is but a small sample of what is discussed in this presentation.
                    High Voltage seed treatment simply supplies the potential for germinating seeds (or eggs) to access the dormant genetics that are ALREADY inside the DNA. Therefore, no genes are changed, the potential is there to simply access the genetic programming that nature itself has built into the plants.
                    The potential is for larger and faster harvests with higher quality food, less fertilizers and little to no herbicides or pesticides. And, for the fact that it takes almost no energy to accomplish these amazing benefits, we could very well be on our way to abundant food production for the entire world without crossing the danger zone that GMOs are known for.
                    • #25
                      . We were waiting for this report and only just now have it available. Whether you have this presentation or not, READ THISHistory, Theory & Practice of the Electrical Utility System by Eric Dollard
                      • #26
                        Conscious Intention, Water & Subtle Energy by Professor Robert Haralick
                        At the 2018 ESTC (Energy Science & Technology Conference), Professor Robert Haralick takes us deeper in the realm of subtle energies by showing exactly how he measured quantifiable changes in water that result from conscious intention alone. This is the companion presentation to the presentation from last year.
                        He also covers many important points about how the experimenter can influence the experiment on a level that goes above the common superficial understanding of this concept. This is taken to a higher level and suggestions are offered on how to clear the influence of intentions on the experiment in order to have cleaner or purer results.
                        Get your copy here: Mind Over Matter - Subtle Energy Protocols, Experiments, Baseline Results & Conscious Intention, Water and Subtle Energy by Prof. Robert Haralick.
                        Get 25% off for a limited time with this coupon: MIND25
                        Prof. Haralick gives the exact components that he uses to measure changes in the impedance of water for the control or unaltered water in comparison to water that is subject to the influence of intention. The results are strikingly obvious – conscious intention alters how well water accepts or rejects the signal from an analyzer.
                        What this shows is how the intention possibly changed the bonding angles or other characteristics. Whatever the change may be, it is unmistakable that the water was indeed changed by consciousness alone.
                        Quite a few experiments are revealed by both graphs, Smith Charts, etc. and Prof. Haralick also reviews various “structured” water and how their boiling point is changed. The most altered appears to have lower boiling points indicating the possibility that the strength that the water molecules are holding hands has been reduced and this is a possible further indication that the surface tension has been reduced.
                        Various water technologies are also discussed as well as his personal experience meeting with the inventors.
                        If you have an interest in water and the effects of consciousness on it, this presentation is for you because you learn exactly how to measure the effects. Experimental protocols that actually work are not very well understood even by many water scientists, but this presentation lays it all out for you.
                        • #27
                          Tewari Reactionless Generator by Anupam Tewari
                          The Homopolar Generator has always been known to be able to deliver electricity without bogging down the prime mover and Faraday knew this 150 years ago!
                          Get your copy here: Tewari Reactionless Generator (RLG) by Anupam Tewari
                          Get 25% off for a limited time: RLG25
                          [VIDEO]http://www.youtube.com/watch?v=SL02k9MOWlo[/VIDEO]
                          Normal generators create a back-torque against the prime mover because of Lenz's Law, which can be explained as an electromagnetic equal and opposite reaction, but this is completely circumvented in the Homopolar Generators.
                          Bruce DePalma simplified and advanced this concept with his invention known as the N-Machine, which is a simple spinning permanent magnet or electromagnetic by tapping the shaft and the outer perimeter of the rotating magnet. Keep in mind this all works without any coils whatsoever! This is completely different from normal electromagnetic generators.
                          Later on Adam Trombly made improvements to Bruce DePalma's methods and when he filed for a patent, the Pentagon served him with a gag order because they themselves apparently had been working on similar technology and many of you know the rest of the story. What they didn't know was that the patent was also filed in Europe and somehow Paramahamsa Tewari who headed up India's Nuclear Power Corporation (a really big deal in India) got his hands on the info.
                          Mr. Tewari worked on replicating Mr. Trombly's work. So the story goes - Mr. Tewari measured how much water could be electrolyzed with a certain amount of electricity. However, when that same electricity powered the Tewari Reactionless Generator (RLG), the output electrolyzed water and he wound up with several times more freed up hydrogen. This defeated Faraday's Law of Electrolysis by a few hundred percent and this led to more advancements and innovations on the RLG technology.
                          Over the years, Mr. Paramahamsa Tewari had continued working on his RLG machine and it has become one of the most tested free energy devices in the world showing at least 238% more electricity coming out of it than going in. This has been tested by very qualified individuals and organizations connected to various companies and universities and the goal is to get this out to the world to help solve the energy problem.
                          Unfortunately, Mr. Tewari passed away toward the end of 2017 but thankfully, his son Anupam Tewari is committed to keeping his father's legacy alive and he was gracious enough to come to the 2018 Energy Science & Technology Conference to present on his father's work.
                          This presentation serves as a perfect starting point for anyone who is not familiar with the Tewari RLG, where it comes from and the how Mr. Tewari's Space Vortex Theory led him to the RLG. Even if you are familiar with the Tewari RLG, there is some history here that many are not aware of and this is coming straight from his son, Anupam, so is authoritative and historically correct.
                          • #28
                            Hidden Dance Zero Force Motor part 2 by Yaro Stanchak
                            Get part 2: Zero Force Motor by Yaro Stanchak
                            Get 25% off: ZFM25
                            The coupon code works for part 1, 2 or the combo at a deeper discount.
                            [VIDEO]https://www.youtube.com/watch?v=1-eaBdWhYEc[/VIDEO]
                            Yaro also shares the differences in more detail on attractive vs repulsive mode and how this looks diagrammatically so the viewer can benefit from these findings. A thorough walkthrough on the Zero Force Motor's timing characteristics of the magnet's geometry in relation to the coil geometry is covered. This is very important and cannot be stated enough - timing is crucial and can make or break your results.
                            Pay close attention to the JZFM Excel data in the table presented by Yaro. You may find there is more than meets the eye. And you will definitely see that at certain RPMs, which may indicate some resonant points, that you will see the Hidden Dance happening within the machine as Yaro shows on the scope.
                            Examine closely the 1989 Ron Cole motor test data to see ZFM operational total power efficiencies of well over 100%!
                            This would be completely consistent with John Bedini's experience over the years with experiments on the Bedini SG when running on and charging batteries, which have shown unusual input Vs output ratios and most of this disappears when running these machines on conventional power supplies. It has been stated over the years that the battery is very important as part of the open system and once again, these ZFM experiments shown by Yaro seem to indicate the same results.
                            • Hidden Dance
                            Get 25% off: ZFM25
                            • #29
                              Dancing with the Aether by Jeane Manning & Susan Manewich
                              Dancing with the Aether by Jeane Manning & Susan Manewich This presentation starts with Jeane Manning who has the pulse of free energy technologies across the globe beyond most.
                              Get your copy here: Dancing with the Aether by Jeane Manning & Susan Manewich
                              Get 25% off for a limited with with this coupon code: DANCING25
                              There is an exciting mention of a new book Jeane is co-authoring with Susan Manewich called Hidden Energy, which will be released in the fall of 2018!
                              Some of these topics are highly controversial, but the data is insurmountable and is presented in a way that is balanced and objective. Susan worked with the late Dr. John Mack and she shares some of her experiences working in this most interesting field.
                              What does a member of The Monroe Institute, a former head of the US Psychotronics Association, a former Harvard Professor of Astrophysics and editor of the Journal of Cosmology and the late Dr. Edgar Mitchell have in common? Susan Manewich was intimately involved in organizing the data that they all collected based on surveys taken by thousands of people. By analyzing the data, a very revealing picture comes into view and it appears there is non-human intelligence that has been influencing developers of breakthrough technologies.
                              Susan also shares a never-before-seen interview with the late Guy Obolensky relating to the power of the mind. She was fortunate to have spent some time with him in his final days.
                              Towards the end of the presentation, Susan covers a very important topic on moral responsibility with free energy technologies as they are sacred and should be treated as such. A business model is shared that anyone can use and takes the above concept into consideration.
                              There are a fair amount of questions at the end that bring up many important points discussed throughout this presentation.
                              • #30
                                Self-Recharging Battery Supply of Carlos F. Benitez by Peter Lindemann, D.Sc.
                                NOTE: This machine was demonstrated at the 2018 Energy Science & Technology Conference (ESTC) but there was no formal presentation. It was only explained to attendees who were interested enough to ask Peter Lindemann questions about it back in the vendor/demo room. This machine is a very small powered demonstration, but proves the point and kept itself charged up all weekend while running a motor/generator. This EXACT circuit from 100 years ago is the foundation for several well-known circuits that have been taught by John Bedini and others over the years - you are being handed the origin of where much of it came from.
                                Get your copy here: The Self-Recharging Battery Supply of Carlos F. Benitez by Peter Lindemann, D.Sc.http://emediapress.com/peterlindemann/benitez/
